can anyone reccomend some settings for coilovers?
ie what to set em to before fitting...
i was thinking -25mm (whatever that is adjustment wise) and medium stiffness?
sound about right?
sound about right?
yes spiky, but i'll want a base to work from...
gonna be sorted by zoo on the 18th (hopefully) but until then i'll want something to work from.
Originally Posted by Rene
Originally Posted by Spiky
coilovers
YOU set them up as YOU want them
pmsl
jim a base???
like i said they are custom....YOU decide
here is how mine was setup
did you have problems with full lock, reversing, or ground clearance or were they stiff enuf not to be a problem?
mine catches the arch when reversing on full lock, but not when going forwards on full lock (well, it catches, but not badly)
but then i do have about 2mm clearance between arch and tyre
i think that its because when youre going forwards the tyre it hitting the arch on the smooth bit where it meets the wing, so it glides over with just a bit of creeking... but when youre going back its getting caught on the open lip...
ive just thoght about what i just said and it doesnt make sense
might get someone to watch me reverse on full lock later to see what catches
Adam Graham
06-09-2015 06:04 AM
