how will long will a std t3 last on stage 3 cos
stupid questio i know
but what would be the the time scale roughly on a std turbo
as far as im aware its a std t3 anyhow
i was going to just put the boost to around 17psi until i can afford the upgrade obviously if it goes then it will be sooner than planned
just wondering if i could get away with it for a couple of months just pottering around witha quick blast here and there
thanks
thanks
held 24psi at 6kish. Sold it a few years ago thou Glad I had one but did get mighty cheesed off with something breaking every other week.
saff is working!!!...atm
not saying it didn't....but a t3 holding 24 psi well up the rev range....na... i've blew 2 holding less than that...(not being a cunt...just sounds odd)
Re: how will long will a std t3 last on stage 3 cos
thanks
thanks
one hundred percent. Owned the car for six years and had the turbo changed about 2 years before the conversion as the original went pop. Was replace with another standard T3 as I couldnt afford anything else at the time.
When I had the conversion I assumed the turbo would give up the ghost shortly afterwards and had the intention of replacing it. Gave it its fairshare of abuse but it just would not die.
Had it tuned 12 months later and had kept pretty much the same horespower. Was told then that I should replace the turbo as a standard one wouldnt last. Never did 'get round to it' months later and still pulled as strong as an ox, although the clutch was beginning to go (and that was the 2nd one !)
Just lucky I guess
Just lucky I guess
ok
ill get it up and running and see what happens
just hope me headgsaket dont go now
espically before xmas
