does any one know about RST metering units
Old 29-11-2006 | 07:29 PM
murco100's Avatar
murco100
Default does any one know about RST metering units
i have no fuel reaching the injecters. there is fuel preasure to the unit and cold start valve and the air flap move freely. thanks for any help any one can give me.
Old 29-11-2006 | 07:34 PM
turbo.jon's Avatar
turbo.jon
sounds like an air leak as same thing happend on mine turned out to be the crap dump valve
Old 29-11-2006 | 07:51 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
You wont get to see fuel coming out the injectors unless cranking the engine while someone pushes down on the flap obviously with the injectors out or nuts cracked on them. can do it yourself by getting the fuel pump to run constantly if your stuck for a pair of hands.
Old 29-11-2006 | 08:02 PM
murco100's Avatar
murco100
cheers for reply. i did remove a injecter and jammed flap open a bit but not a drop came out. i didnt know weather it might be something to do with the preasure actuator on the side of the unit. im not sure what this bit does
Old 29-11-2006 | 08:40 PM
The Sludge's Avatar
The Sludge
garibaldi
cud be the black box control unit onthe side??
A.t.p
23-10-2015 08:54 PM
07-10-2015 01:56 PM
gingeRS
17
02-10-2015 10:42 AM
Steve Escos
01-10-2015 07:57 AM
