Rocker cover gasket failure ? cosworth
Ive got a problem , with oil getting into the gallerys aroun where the spark plug sits people ?
New gasket has been fitted and have this problem ? just took my rocker cover off and where spark plug 4 is and the rear of engine is full with oil
and 4 bits that surround the plug
Any tips or advice on why this is happening ? Quite straight forward on fitting it , unless im doing something wrong as per
Previously the car didn have a gasket on it for some reason
and had a bit of oil in therer but obviously thought the lack of gasket was the reason ? but now its worse but only at the end , car runs fine too , but i know there should not be oil there obviously
Any help appreciated , it was a new gasket from woodford
Cheeers peeps , shit myself today when it was full of oil in there , a new gasket then ? again
Did you use paste euan to the head then rocker cover down ontop of gasket ? think iL just paste the whole lot lol
Agree with above use a Cometic as its slightly thicker, the ford ones can sometimes tear or get bent over causing leaks into spark plug holes which will gve you a misfire in the end when it fills up.
Simon.
Simon.
JoeyBoyden
18-08-2015 10:52 PM
