Rover 820 Vitesse Turbo
Old 16-11-2006, 07:16 PM
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
Default Rover 820 Vitesse Turbo
Anyone had any experiance of these? A mate has one and is looking to get rid of.....
I've only ever heard of the 600 Turbo tho
Now i know its a Rover, so lets avoid the usual responces! I just want information on the engine/turbo and what the hell a Rover 800 is like
I'm guessing its going to be a tank
Old 16-11-2006, 07:19 PM
L33 BYT
L33 BYT's Avatar
Just check you get the 200BHP model and not the 180.
They mark there terratory like a dog in regards to leaking oil. Check for head gasket weap at the front right of the engine.
Old 16-11-2006, 07:20 PM
James
James's Avatar
it's the same engine as used in the other models. 420/tomcat/600ti.
getting quite thin on the ground now-a-days..
Old 16-11-2006, 07:22 PM
BillyCabrio
L33 BYT
How will i know the difference?
James
Same engine, heavier car?
Old 16-11-2006, 07:24 PM
BillyCabrio
Is this one?
http://www.austin-rover.co.uk/xxtickfordf.htm
The one my mate has is an R reg on a 1998 so i'm guessing its one of the last on the run?
Old 16-11-2006, 07:26 PM
xr4x4rs
xr4x4rs's Avatar
the 600 uses coil pack
220/400/800 uses dizzy
carnt remember which model but one of them does have shit pistons
usual thing is headgasket, they always leak on passenger side front corner
can get a metal headgaslet for them though used be rover but god knows where now lol
later models had metal gasket as std
other than that good cars looked after will be reliable
Old 16-11-2006, 07:28 PM
xr4x4rs
xr4x4rs's Avatar
Originally Posted by BillyCabrio
Is this one?
that one uses a m series turbo engine, very rae and a better engine
they changed it to the t series which is in all turbo rover cars
Old 16-11-2006, 07:30 PM
BillyCabrio
So its worth a look over then?
Old 16-11-2006, 07:31 PM
L33 BYT
L33 BYT's Avatar
As long as its cheap. Deffinatly.
Old 16-11-2006, 08:30 PM
L33 BYT
L33 BYT's Avatar
FYI 200PS Model has lower suspension. Bigger 17" Wheels.
The Cams are the key and pulleys should be stamped up as
100029 inlet cam and a 100028 exhaust iirc
Old 16-11-2006, 08:31 PM
BillyCabrio
L33 BYT
Cheers mate
Keep diggin'
Old 16-11-2006, 08:37 PM
SapphyMike
SapphyMike's Avatar
If its an R Reg it will be a 200bhp (197) model.
I had an M Reg one - i actually liked it, and the seats were the proper recaro's, not the crapper ones found in the 600 Ti (which i have). Some of the 800 Vitesse's have full leather, these are often knows as Vitesse Lux.
The gearboxes are made out of softer chocolate than Scooby engines Rover limited the boost in first gear to save the box. this can be got around to make 1st more lively. two much wheel spinning is bad for them.
They have a tall 5th gear, good for cruising.
It should already have the Klinger (metal) head gasket on it with it being an R reg.
Pre 96 cars were either Vitesse or Vitesse Sport (the sport had 17" alloys etc)
The post 96 cars had the crapper AE pistons iirc. but tbh, run less than 13psi and all should be well.
Old 16-11-2006, 08:43 PM
BillyCabrio
Things are looking better all the time
I'll have to get my arse down there and have a lookie me thinks
Old 16-11-2006, 09:03 PM
xr4x4rs
xr4x4rs's Avatar
also dont let the alarm fob battery go dead as this does the immobilsor
if it resets the ecu when the car batt is dead aswell have fun
no more than 13 psi as stated 12 to be safe as the ecu carnt fuel for that much boost
also they have no tdc markings on bottom pulley to do a cambelt, theres a locating pin in flywheel but ive seen people do it with he pin but 180 degress out aswell
Old 16-11-2006, 09:04 PM
L33 BYT
L33 BYT's Avatar
I'm guilty of that.
Old 16-11-2006, 09:10 PM
BillyCabrio
So overall, if i stick to running the 12-13psi......... Are they fairly reliable cars?
Any niggles or typical Rover things i should look out for?
Old 16-11-2006, 09:11 PM
xr4x4rs
xr4x4rs's Avatar
seen it done a fair few times
i wont do them now as there too much of a pain in the arse taking engine mounts off etc to do a cambelt is stupid aswell
Old 16-11-2006, 09:13 PM
L33 BYT
L33 BYT's Avatar
Noisy gearbox @ idle which dissapears when clutched pushed down.
Old 16-11-2006, 09:16 PM
L33 BYT
L33 BYT's Avatar
Just been told if you give me the reg I can tell you what power she will be.
Just remembered I have a Rover EPC on my PC.
Old 16-11-2006, 09:18 PM
xr4x4rs
xr4x4rs's Avatar
thats clutch release bearing
Old 16-11-2006, 09:22 PM
L33 BYT
L33 BYT's Avatar
wish it was. was told on mine it was the main bearings.
Old 16-11-2006, 09:26 PM
L33 BYT
L33 BYT's Avatar
VRN: R*** ***, VIN:SARRSWWVGWM252660, MG Rover, 800 (RS), Class 5, Saloon, 5 door, T Series, 2000 cc, Petrol, Multi pnt inj long track inlet std, 16V, 4 Cylinder, Turbo, 3 way catalyst, 200PS, 5 Speed, Manual, W4, RHD, Model Year: 1998, S/N: 252660
Old 16-11-2006, 09:30 PM
xr4x4rs
xr4x4rs's Avatar
possible as some use plastic case bearings
what you want is a pg1 gearbox and fit the lsd in
just need to get the rite one as soe holes are bigger than others
Old 16-11-2006, 09:32 PM
L33 BYT
L33 BYT's Avatar
I need to get hold of a tubby box one for my GSI. As mine wines more than a woman with pmt.
Old 16-11-2006, 09:38 PM
BillyCabrio
Old 16-11-2006, 09:39 PM
xr4x4rs
xr4x4rs's Avatar
yeah
should be able to get one though
they use a torsion diff instead of lsd
Old 16-11-2006, 11:14 PM
PROMETHEUS
PROMETHEUS's Avatar
I got a rover 220 gti for Ł60 notes last winter as a run about, cos it needed a new gearbox fitted, which was in the boot! Got a set g-max suspension from a breaker for Ł50, a stainless exhaust from a breaker
and a decat and filter of my old man, oh and a stainless scorpion exhaust had about Ł250 in it, nailed it everywhere and I MEAN NAILED IT, blew a golf gti 16v and an imprezza turbo on the back roads thru handlin, its not always horsepower, just grunt and balls. Wish i had it this winter lol, hmm
Old 16-11-2006, 11:33 PM
-scar-
-scar-'s Avatar
They weren't a bad car in their day. Lancashire Police had them as their Armed Response Vehciles, blew a few engines in them simply by selecting the wrong gear
Handling was the main problem with them though - good on the Motorways but shoite on the back roads!
Old 16-11-2006, 11:46 PM
swfc50
swfc50's Avatar
check for noises from the gearbox when the clutch isnt pressed. Have a look underneath, oil dripping from the drive shaft seals is a dead giveaway for the usual diff bearing problems. If it has a genuine turbo box fitted it will be a TorSen btw.
Little bit of oil weeping from the corner of the block is no big deal.
The pre and after 96 piston thing is a load of shite, they are all weak appart from the mk1 800 pistons (m series). Run no more than 12.5psi and good times should be had by all
Old 17-11-2006, 09:39 AM
SapphyMike
SapphyMike's Avatar
the 800's suffered shite electrics and dash lift as well
Old 17-11-2006, 09:52 AM
rsnissan
rsnissan's Avatar
i have an stearling as a run around, anyone know how to reset the bloody SRS light on the dash
the 800 is a comfy car and eats the Mway, far more relaxing than the cossie to drive but mine is the 2.7 V6 auto. Had a T series in my old 420 GSi love that car and they do catch people out when the Torsen doesnt shit it self
Old 17-11-2006, 10:16 AM
banhambuilt
banhambuilt's Avatar
i have a rover 620ti engine in my maestro.
twin cam,fuel injection,stage 2 t25 turbo,dyno`ed at 260bhp
bit of a monster in the maestro.
it runs an omex ecu (needed if you wanna run good power)
uprated steel caged bearings in the box type b torsen diff (better than the older type a torsen)
they are very under rated cars,just dear to get power out of
dave
Old 17-11-2006, 10:23 AM
xr4x4rs
xr4x4rs's Avatar
dave
let me guess
white
rollcage
evo stlye front bumper
front mount intercooler
mgf wheels
lowered
omex management
have a feeling i know the car as i helped build it and load your van up with the spares aswell
i done all the wiring on it complete car loom plus management and extras until the omex was fitted
Old 17-11-2006, 10:27 AM
banhambuilt
thats the 1
minus cage and buckets now though,looks better standard
dave
Old 17-11-2006, 10:29 AM
xr4x4rs
xr4x4rs's Avatar
no way
what happened to the riguard seats
he had them specially made as these were what were used in the maestro cup trpohy cars
the cage finished the car i think
makes people a bit more suspious when they see a maestro with a full cage
Old 17-11-2006, 10:39 AM
banhambuilt
still got the seats.
it`s a real street sleeper now
dave
Old 17-11-2006, 11:30 AM
xr4x4rs
xr4x4rs's Avatar
pics
see how much its changed
Old 17-11-2006, 11:35 AM
Nash
Cake lover!
Nash's Avatar
Just have a look on totb website from 2/3yrs ago for what won the FWD handling
Old 17-11-2006, 03:47 PM
BillyCabrio
Well i'm hopefully going to have a nose over the weekend, take the big guy with me too
Old 17-11-2006, 04:18 PM
celsisone
celsisone's Avatar
They are big cars yes, but they do move. manual is a must. all late rovers are dissy less twin coil pack. think it was 1996+. not many 800 vitesse had LSD's. you may be lucky. All rover turbo's have a over boost Valve as standard, Under the airbox. Wouldn't run anymore than 12psi on it.
Quick Reply: Rover 820 Vitesse Turbo
