What Bushes?
What Bushes?
What bushes do people rate?
Only need a few on my car as most is solid mounted.
Do i stick something like powerflex on? or maybe just new ford items??
Or do i go the extra bit and get nylon items done.
only need ARB Mounts Front & Rear (Inners and outers)
Also need some front suspension top mount bushes? any advantage to getting anything other than new ford items?
Ryan
Ryan
Guest
Posts: n/a
look @ my rear ARB mountigs i welded in (resto section).....im using droplinks instead of the OEM rubber ones that i make myself. uppers i replaced with powerflex, although was just thinking today when i had them in my hands that they are softish....
michael
michael
can you fit std top mount bushes with those 'very special' top mounts?
I've always found the proper Ford bushes the best... for road use that is...
michael
michael
yes paul, you use standard mounting bushes on those special items
Micheal, i think i might just use standard bushes then and skip powerflex.
B9kos, no i havent mate, been a bit too busy these past few days will find out this week though, as i pick up the mounts hopefully tommorrow
so will need the bearings to install them in my car
Originally Posted by Ryan
yes Paul, you use standard mounting bushes on those special items
Ryan
didn't you get anything from that bearing number i gave you ?
marco
DavidK
27-09-2015 02:55 PM
