changing tca's ?
Resident Wrestling Legend
get both sides of the car off the gorund first
pop the bottom ball joint (don't undo the torx bit, undo the nut)
if you can wobble the ball joint easily with your finger it's past it's best
if it's stiff then it's ok
putting a new tca on is a mix and match job, get yourself a ratchet strap to make life easy otherwise put half the arb bush on first, push the inner in and then put the outer abs bush back in again
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
