nokia N80 camera help
Old Nov 9, 2006 | 01:49 PM
xr-stu's Avatar
xr-stu
Default nokia N80 camera help
got an N80, got a 3megapixel camera but the quality is shite, its just the pictures come out MASSIVE. the quality isnt much better than my old 6600, but the picture is about 6 times the size, its really annoying.
anyone know how to change this? ive messed about with the settings which basiclly changes is from 3mp down to about 1mp, which means the picture is smaller but slightly worse quality.
really frustrating!
ive got a 2megapixel digital camera thats like 5 years old and the quality is sooo much better than my phone - which should be better in theory!
Old Nov 9, 2006 | 06:14 PM
DazC's Avatar
DazC
Hello,
There are so many settings on the N80 for the camera it is easy to fook the picture up by not having it quite right.
I advise that you keep the macro setting off and keep it on landscape unless you are doing close up shots (thats the little switch uner the camera lense if you're not sure. The flower is macro).
Keep it set on 3mp. You can play about with colour balances and other stuff but I wouldn't bother. When you take a picture, make sure you keep really still and stay still for a few seconds after you have pressed the button.
You can also set the cammera up in shooting mode for different circumstances.
You can get some good pictures out of the N80 under the right circumstances.
Old Nov 9, 2006 | 06:17 PM
Big Andy W's Avatar
Big Andy W
Yes the silly switch on the back indeed Daz
I took 40 photo's during 2 days at the alton towers hotel and they all came out shite cause the switch was wrong!
Mint when its in 3 mega mode!
Old Nov 9, 2006 | 06:36 PM
DazC's Avatar
DazC
Andy,
If your phone isn't on V4 software, get it upgraded.
Press *#0000# and it will tell you what software you're on. Mine is on V4.0623. It's like I'm using a different phone. almost all of the little glitches are gone.
Old Nov 9, 2006 | 11:25 PM
Big Andy W's Avatar
Big Andy W
the only one that pisses me off is the time it takes to send a message!
I'll check tho!
v 3.0617.0.6
i'll get it upgraded!
Old Nov 10, 2006 | 11:46 AM
WD Pro's Avatar
WD Pro
How do I get it upgraded ?
cheers
Old Nov 10, 2006 | 03:50 PM
slowpoke's Avatar
slowpoke
as WD says where can i get my firmware upped ?
must admit as andy says mint phone but it takes bloody ages to send a text message
a lot lot better now that tom tom runs on it
Old Nov 10, 2006 | 05:38 PM
DazC's Avatar
DazC
You need to download some software for the messages. Hang on 2 minutes and I will find it...
Old Nov 10, 2006 | 05:44 PM
DazC's Avatar
DazC
Link to the SMS accelerator. It's installed on my phone and it's mint! Loads faster.
http://www.europe.nokia.com/A4149142
This can be loaded onto the phone by bluetooth, USB cable or Infrared.
To update your firmware, use the USB lead you got with the phone and go to the follwing address.
http://www.europe.nokia.com/A4176089?N80
Follow the on screen instructions but before you update your phone, I suggest you shut all Nokia related software and plug your phone into the PC. Wait for it to load the drivers (comes up with new device found and all that shit) when it says your device is installed and ready to use, then open the updater and follow the on screen instructions.
Old Nov 10, 2006 | 05:45 PM
DazC's Avatar
DazC
Or you could just take it to your local Nokia service centre and get them to do it.
Old Nov 10, 2006 | 07:10 PM
slowpoke's Avatar
slowpoke
fookin superb daz
do i install that sms speed up thing as well as the firmware update or does the firmware sort it out ?
Matt
Old Nov 11, 2006 | 12:13 PM
DazC's Avatar
DazC
Yes mate.
Just be very careful when updating otherwise you could end up with a fooked phone if you interupt the update.
Old Nov 11, 2006 | 12:14 PM
DazC's Avatar
DazC
I'll check tho!
v 3.0617.0.6
If you struggle getting it done Andy, give me a shout and I'll do it for you.
Old Nov 11, 2006 | 01:45 PM
slowpoke's Avatar
slowpoke
daz when you say nokia related software for the firmware what do you exactly mean ?
dont want to fook my phone lol
Matt
Old Nov 11, 2006 | 02:26 PM
DazC's Avatar
DazC
Just don't run PC Suite or the firmware updater until windows has loaded the drivers for the phone.
Plug your phone into the PC and it should come up with the found new hardware bollocks. Just wait for it to finish installing the drivers and it tells you your new hardware is installed and ready to use, and run the firmware updater.
Old Nov 11, 2006 | 03:53 PM
slowpoke's Avatar
slowpoke
when i connect the phone to the pc it asks for the drivers and then wants to go and look for them, then says cannot install this hardware and it might not work properly ?
matt
Old Nov 11, 2006 | 04:03 PM
slowpoke's Avatar
slowpoke
just installed the pc suite thing and it knows its there now at least
Old Nov 11, 2006 | 06:15 PM
DazC's Avatar
DazC
You need the PC suite to send the SMS accelerator to the phone anyway.
I already had PC suite installed before I connected the phone by USB for the first time ever (I always used bluetooth before hand).
mk1turboestate
20
Dec 9, 2015 12:15 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
