Can any electricians help please?
#41
GARETH T
Dont worry mate i AM an electrician by trade and a pretty decent 1 imo, i'm 24 now and even as an apprentie i used to look at some of the veterans work and think "fuck me".
I once pulled a 1 gang 1 way light switch off and it had 4 twins in it all connector blocked behind the plasterboard backbox, the block replied to fuck me with "whats wrong with that like you cheeky cunt"
What i hate the most is people think cause it works its right
#44
Originally Posted by Alps Pacino
I aint done much in domestic i was more comercial and industrial, i'm now a trainee rov technician so wont be doing houses again ever with any luck ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
#46
GARETH T
Fuck chasing walls thats what the labourers are for they get paid for what they do not what they know, Myself on the other hand gets paid for what i know not what i do
#47
#49
Originally Posted by danneth
domestic is where all the money is dont knock it
#50
The hob is gas. The oven is 6.2kw.
Therefore it MUST BE connected straight into the cooker connection unit using 6mm cable. The breaker should be 32 amp rated in the consumer unit and most probably will be. DO NOT connect a 1.5mm cable as this will melt.
Some oven are 3kw and can be connected using a plug but NOT connected into the connection unit as the cable needs to be fused at 13 amp in the plug. There is no fuse in the connection unit. If anyone has connected a 3kw oven straight into the connection unit you should remove it, unless the breaker in the consumer unit has been changed to 16 amp. Otherwise you would have 1.5mm fused at 32 amp in the consumer unit which it will not carry safely.
Sorted
#51
danneth
Being an rov tech is where the money is between Ł280 and Ł320 a day depending on who and where you work,![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#52
danneth
I'll have 6 months of the year off![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
And as i said above i sit with 1 hand on a joystik driving an rov all day looking at monitors real hard work that is, i really pull me plums out for my 300 snots a day
#53
danneth
And as i said above i sit with 1 hand on a joystik driving an rov all day looking at monitors real hard work that is, i really pull me plums out for my 300 snots a day![Top](https://passionford.com/forum/images/smilies/smile011.gif)
i get to work in rotherham on the " decent homes scheme " all them single mums
i think i win.......
#57
Iget to work in Amserdam, singapor and many other exotic locations i think i win ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
#58
Alps
The radial itself is 6mm twin and earth from a 30 amp fuse in the unit, to a double pole switch, then 6mm to the cooker connection point. Then the cooker is fitted to the connection point with the supplied 1.5mm rubber flex..
I do our wiring in extensions etc, and as it is all part p etc now they have all been checked off by Building Control and passed. I have never had to re do anything but if this with the electric cookers is wrong i need to know for the future
And ill be writing to stoves etc
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
#59
Originally Posted by Lee Reynolds
Alps
And ill be writing to stoves etc ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
#60
ok mate cheers. Im going to have to look into this more as to why the oven are supplied like this. End of the day i have a business to run and cant aford mistakes like this due to poor instructions etc etc
I do everything by the book, so if the instructions from reputable manufacturers state XXXXXXXX then thats how it goes...
cheers pal
cheers pal
#61
Series1Dry
If its a 1.5mm mate it should be a 6a not a 16a.
A radial power circuit is 2.5mm and protected by a 16a breaker. Ring mains are 32a protected and 2.5mm becuse the cross sectional area is doubled cause your using 2x2.5mm so the mcb can be doubled as it can take twice the current.
#62
Lee Reynolds
Not 1 to argue or disagree but every oven have installed has had a piece of 6mm twin and earth hard wired into the cooker terminals, then the other nd connected to the local cooker switch which is located near the cooker. The cooker outlet is wired back to the board. There is no fuse or mcb in the cooker outlet so if the cooker flex was only 1.5mm it not going to be protected by the 32a mcb that is protecting the cooker circuit.
Think about it the cooker goes into fault the 1.5mm starts to smolder and sets on fire so you rush into the kitchen thinking the spuds are burning but its really its the ceiling
This has been probably 4 times
#63
Series1Dry
A radial power circuit is 2.5mm and protected by a 16a breaker. Ring mains are 32a protected and 2.5mm becuse the cross sectional area is doubled cause your using 2x2.5mm so the mcb can be doubled as it can take twice the current.![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Changing it to 6amp would be no good cos it would trip out when you turned the oven on !
#64
Lee Reynolds
#65
Dann, on the ovens i have fitted before using the said 1.5mm flex, going to the connection point into 6mm i too thought WTF is htis all about, 6mm, then this thin shit
So looked at the terminal in the oven and as you say its like speaker wire..so i presumed they must know what they are on with and the flex is fine.
#66
Lee Reynolds
Just been round me mates house that hes just bought and its got a cooker there with a 1.5mm flex WITH PLUG plugged into the cooker terminal.
Are th cookers your fitting gas cookers with an electric ignitor????????/
I'm guessing the cookers you hav intalled need plugging in and not hard wiring.
#67
Alps. I really appreciate your help mate honestly and please done take this the wrong way, BUT, WTF do you think i am?
Like id mistake a gas cooker for an electric.
Yes i have fitted gas and plugged in the ignition cable into a socket in the cupboard next to the oven..But i really am talkin electric here...
van_dogg_pavvy
03-03-2016 09:30 AM
geoffxr4
02-11-2006 09:00 AM
DaveEscos
11-02-2005 11:33 AM
