WHAT DAMAGE CAN A SPARK PLUG TIP BREAKING OFF CAUSE?????
developed a missfire on my saph at donnington last weekend found out it was because of 1 of thespark plug electrodes breaking off. I think it did leave via the exhaust because someone saw something fired out the tail pipe & couln't pick up anything in the bore with a magnetic pick up tool.
have done a compression test & still have 185 psi on all cylinders, turbo boosts fine, no smoke or noises.
could it have done some internal damage or I have i been very lucky?
Yeah sounds like you've been VERY lucky......I had the tip off a ShitFire plug come off & melt its way through an exhaust valve on my first 21Turbo - back when I was young & didnt realise there were different heat rated plugs...oh & before I realised that SplitFire plugs were a load of advertising hype load of my arse pieces of CRAP!!!
PF Idiot Sniper
Originally Posted by Mike1
What would cause such a failure to a plug that had been running for that long? Indetectable det? A sudden weak mixture on that cylinder?
I'm in a similar boat to you but havent investigated the problem. I got a reek of smoke out the back then cruised home the last mile and switched off. Number 1 lost the tip of the plug
Originally Posted by Lambchop
[That's the million dollar question ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
I'm praying the piston isn't holed but wont know till i remove the head. Havent done it yet because it'll turn into a money pit and i need money elsewhere just now!
PF Idiot Sniper
NGK BCR8ES and i'd be guessing the gap...hmmm....honestly i cant remember ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
So your engine is ok and im praying mine is too but what happens if you throw in a new plug and a month later the whole engine melts?![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
I've spoken to someone else on here who melted a plug, tuner checked and found nothing wrong and no det etc then 2 weeks later complete melt down. I cant afford that!!!!
I was on my 6th session of the day flying round donnington & the plugs had been in 18 months. was flat out in 4th at 24psi held when it started to missfire
PF Idiot Sniper
Originally Posted by IANS2RST
was flat out in 4th at 24psi held when it started to missfire ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Bastard car.
Are the 071s more prone to failure than the older superseded 701s? I've heard they have a shorter working life - is that because they are side gapped?
PF Idiot Sniper
Yes they were gapped correctly because they were not long changed. I had a fucker of a missfire where EVERYTHING was changed and it was eventually found to be a dodgy petrol tank
Have you got/had a similar problem that you're asking Q's?
Looking at both failures it seems they may have occurred when the car was held on boost for a while. Could the failures have been attributed to a mixture problem at high revs ...i.e lean ...causing extreme heat.
Would that NGK you used have been slightly too "hot" a plug for that boost Lambchop? Or was it recommended to you?
Edited to say you beat me to it with your reply Lambchop!!
I wasn't saying you had the wrong plugs/did something wrong by the way - was just interested in what happened - possible causes.
didn't get any smoke just the missfire, heard a whizzing sound which coincided with something bright orange flying out of my exhaust
have an afr meter in my car which was showing well into the green
have got a new set of plugs fitted & all seams ok.
coming off the road soon for some bodywork anyway & will be checke over before it sees a track again
PF Idiot Sniper
Next time i get tuned instead of my usual fuck it give me max bhp attitude i'll knock it back to a safer zone
Tank Mike
Ford Focus ST Parts for Sale
18-05-2016 09:38 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
