WHEEL SPACERS.
WHEEL SPACERS.
Am trying to fit FOCUS RS BREMBOS on my SERIES 2 ESCORT RS TURBO.But unfortunatly the rims foul the calipers.They need to be spaced out about 20mm.Would these be suitable?????
http://cgi.ebay.co.uk/2-x-24mm-FORD-...QQcmdZViewItem
Originally Posted by S2martin
i think a set of spacers from halfrauds is only a tenner mate
Yes but using NORMAL SPACER you loose the lip on the HUB so your rims have nothig to sit on .But these HUB CENTRIC spacers keep the alloy SPACED OUT but still CENTRAL TO THE HUB.Just wanted to know if spacing a wheel 20 mm from the hub is safe ?
Ex Full Price gold member
Originally Posted by Steve_B
Yes they'll work but won't the ally sit out toooo far with a big spacer???, I've used hubcentric spacers on 2 Cossies on the rear to fill the arches out
I would look more at trying to move the calipers inboard and use a set of bells/rotors with a different offset.
I had 15mm Hub Centric Spacers on my FRST but that was only to counter a set of rims with the wrong offset, I certainly wouldn't space the wheels out 20mm.
Former Sponsor
I had 15mm Hub Centric Spacers on my FRS but that was only to counter a set of rims with the wrong offset, I certainly wouldn't space the wheels out 20mm.
Adam Graham
06-09-2015 06:04 AM
