cam timing ?
Old 30-10-2006, 06:48 PM
mitchrst
1981
mitchrst's Avatar
Default cam timing ?
when fitting a decompression plate would it retard the cam timing or advance it ???
Old 30-10-2006, 07:10 PM
project rs
project rs's Avatar
if it's on an escort i don't think it will do anything as all your doing is moving the head and block apart by a small amount the cam timing is controlled by where the teeth are set in the two pulleys nothing else unless you've got an adjustable pulley
Old 30-10-2006, 07:15 PM
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
Depends how thick the plate is but if your using a vernia as said you can compensate. A friend of mine is running approx 2mm plate and the teeth on the belt no longer line up on the std cam pully with every thing timed up due to the head being higher up
Bri.
Old 30-10-2006, 07:17 PM
the cam pulley and the bottom pulley have to be a whole number of teeth apart though, and you just slightly lengthened the gap they are, therefore the top pulley now has to move forward slightly (advance) to sit cleanly on the teeth again.
RUBY123
22-10-2023 12:04 PM
Danielbetty
03-10-2015 06:01 PM
martsmotor
Ford Focus Range
27-08-2015 08:08 PM
JoeyBoyden
20
22-08-2015 03:23 PM
taylora1409
12-08-2015 12:06 PM
Quick Reply: cam timing ?
