Electrical Gremlins ! HELP
Old Aug 27, 2004 | 10:36 AM
Tony Ryan's Avatar
Tony Ryan
Default Electrical Gremlins ! HELP
on a distributorless ignition system ,pectel loom , P8 already converted to run it etc.. ive got power to the coil pack , power to the ignition amps , a pulse from the injectors but NO spark at the plugs , cant work it out ! changed the crank sensor and re-gapped the phase sensor , got proper earths but still nothing ! As you let go off the key a spark does appear at the plug and makes the engine cough so i know it will go , but where is the spark during cranking ??? Anyone had this before ,
Old Aug 27, 2004 | 10:58 AM
Doug's Avatar
Doug
Tony are the 2 outer wires on the coil pack multi plug switching ? check with a test light whilst its connected to the coil pack and cranking over
Regards Doug
Old Aug 27, 2004 | 11:44 AM
Tony Ryan's Avatar
Tony Ryan
Hi Doug , how are you mate ?? I know there is power to the centre pin , the permanent live but im not sure about the outer ones and my sparky has gone AWOL on a jet -ski for the weekend, if we assumed they are not ( as these are the feed for each side of the pack and its not sparking ) what do you think the cause of this could be ?
Regards
tony
Old Aug 27, 2004 | 11:53 AM
Doug's Avatar
Doug
Yeh im still breathing tony
with the plug connected you should have a feed on the centre pin and the 2 outer pins should also be live and switch earth as you turn it over check that and get back to me
Regards Doug
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
