Carb experts. Quick Question.
Old Oct 22, 2006 | 01:45 PM
L33 BYT's Avatar
L33 BYT
Default Carb experts. Quick Question.
I just bought I better rated Carb for my quad as a direct replacement.
Boy what a difference it makes. But I have a problem and wondering if you could help.
It basically pissing fuel from a pipe connected to the bottom and also its coming out from the K&N filter I have on it.
Would this be stuck floats allowing it to overfill??
Old Oct 22, 2006 | 01:55 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Sounds like it is stuck float, is the carb level, and also you say its leaking from the pipe on the bottom of the carb, is this the float chamber if so there will be a screw on the bottom, tighten this up as its to drain the chamber.
Bri.
Old Oct 22, 2006 | 04:20 PM
L33 BYT's Avatar
L33 BYT
Bri, the drain screw is secure. The carb is level but not when im tearing up Heath land I'll take her apart and check the float.
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
sridgett
Oct 1, 2015 07:30 PM
locum8
Oct 1, 2015 01:50 PM
