rs2000 engine in a mk2 or mk3 xr2
i got a rs2000 engine that im thinking of puting in a mk2 or mk3 xr2 track car
dose any one now if it will fit
The Rs2000 engine is all steel and was never fitted to a fiesta. The ZETEC was fitted to fiestas, has an alloy head, is easier to tune, spares are cheaper and engines are cheaper. Why waste time and money on second best?
Fucking superstar........
Originally Posted by zetecnutter
why is it a pig to fit measurements are the same - its just about finding the right mounts etc
the rest is simple enough and a bit of time
The engine mount is a different design hence you'd have to make one up from scratch.
The gearbox is an MTX75 which will prove dificult to fit into a Fiesta XR2, and if you want to run a BC box out the XR2 or an RST or something you'll need to use a 220mm flywheel like the XR2i or something which would require drilling to fit.
Why go through all that hassle? When a zetec is cheaper to buy, lighter and literally drops right in?
The I4 also weighs a ton and won't do you any favours in the handling stakes with all that extra weight over the nose. 2.0 Zetec really is th ebest option for you
ive already got a i4 on bodies with the management waiting
gearbox you use a s1/s2/diesel or u can have a ib5 on there you just need to get the starter that goes on the rear of the zetec to fit
you dont need to a custom mount ive managed to find out what one you need - flywheel is ??? at the mo
iam going to give it a go starting this weekend myself but its not in an xr2
Pwrs2k
120
16-10-2015 03:16 PM
Ben26
27-08-2015 08:56 PM
