Identifying Sierra Suspension
i want to get some new springs for the saph, but i dunno wot suspension its got on it... i'm told its 4x4, but how do i check?
i know the rears are the same on all of em so thats not a problem, but what about the fronts? is there an easy way to tell what springs i'll need?
also what kinda drop do you recon? i was thinking -25mm?
car is running esccos alloys with 205 profiles on em... and it has a front splitter, so i dont want to get rubbing or anything...
ta
ta
Spanner monkey
Can't remeber what the spring colours are mate for a 4x4, i can look oin my escort but i think they are different to saff??
i will have some nearly new escort cossie standard shocks soon as i'll be putting konis onto it, they have done about 2k miles, you want them for £50??
Oh, and the car looks proper
kev, its got std suspension on it at the moment... it looks low coz theyre old, and the springs aint quite up to the job of supporting the big ol v6.
i might just get a full kit tho, how much are konis for a saph? about 400?
ok from what i can tell theres only a few types listed:
normal 2wd
cossie 2wd
and 4x4 (all models)
then you got the estate etc. with coilovers on back etc....
so what distinguishes the 2wd and 4x4 apart... is it just the hub mounting? or topmount too? i assume that if the car has 4x4 hubs then i use 4x4 shox, and if it has 2wd hubs then i use normal shox, and 2wd cossie hubs i use 2wd cossie shox... right?
the car has 4x4 brakes, so its likely that its got 4x4 hubs... i'll check later...
normal 2wd
cossie 2wd
sorry mist your post
from what im told it was from liverpool, and now its it herne bay... now im takin it to bromley
dan, i cant afford fookin coilovers i WAS planning on spending 80quid on springs... even konis will take me way over budget... lol
aso will coilovers go on the rear with my wheel/tyre combo?
from what im told it was from liverpool, and now its it herne bay... now im takin it to bromley [/quote]
I thought so, It was for sale for about 1yr about 2yrs ago @ £3500 was offered to me when I was selling a modded S/2 back then! did look nice
£410 incl postage for cash, you could give me the money tomorrow night and i could give you the coilovers at wednesday's pf meet, it's up to you
dan, any chance of getting em any sooner? say for sunday/monday? (if i collect?)
also is that price the same for the 2wd, 4x4 etc. etc. asi still dont know what suspension is on mine
ok sod it i'll take em (i assume its a full kit yeah not just shox on their own?) booked into zoo on the way back from MSD now
so much for buying a car n not spending any money on it
could be worse tho ya could wast ya money on drinking and taking drugs
can you beat danvisteon's price
ps need to check mine's got 4x4 suspension 1st... i havent had an answer to the Q yet
its simple, check to see if you have a front diff, if you havent then you have 2wd suspension, then check the colour coding on the struts to see if their cosworth or normal 2wd, i cannot remember what colour coding cossie is (think its red.white.red) spadge or other cossie breakers will know . cheers nomad
ok so if its a 4x4 hub its deffo 4x4 suspension right?
but if its a 2wd hub, how am i gonna distinguish it between a "normal" 2wd hub and a cossie 2wd hub? bearing in mind the car's a 2.0 GLSi so it may have "normal" 2wd hubs on it still...
Spanner monkey
cossie 2wd hubs will be different than other hubs as the 2wd calipers have wider bolt holes so won't fit unless machined onto a standard hub and vice versa!
so we saying that if its got 4x4 brakes and 4x4 hubs... its 4x4 suspension
if its got 4x4 brakes and 2wd hubs then its normal 2wd suspension
am i right there gadge?
jim measure the strut where it goes in the hub
2wd = 45.5mm
4wd = 50mm ish
i can't get the struts till next week as they are waitng for the teflon coated piston rings to turn up and they are due tuesday, is this ok???? BTW the delivery is next day
2wd = 45.5mm
4wd = 50mm ish
its not a problem, its just i'm up in essex all weekend workin on car so coulda killed 2 birds with 1 stone...
also those measurements you just put down, are they for cosworth only? ie is a 2.0 GLSi also 45.5mm?
cheers dan
cheers dan
weight of engine possibly coz a cossie has more weight at the front end with the turbo, intercooler and the other gubbins, so it could just be that, if you can measure the strut and let me know i can get the correct set made for you
cheers
dan
cheers
dan
Spanner monkey
SMILER258
28-09-2015 09:04 AM
