modifying oil return to the sump kits- turbo leaking FIESTA
who sells these kits or who can make them, cant do any calling today as its a sunday.
would this stop this oil leak as i have tried everything i can think of- the fiestas drain as standard takes it to the block.
http://www.fiestaturbo.com/forums/tu...03/?highlight=
best regards
best regards
Do you have fitted the later oil return which connects to the block in the form of a screw thread?
Sean_RS made this modification to his oil return and now doesn't leak.
I think he has a spare one too, i've not seen any relocated to the sump itself.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
its the return that goes into the block via a push fit connector, just a brand new factory ford part.
have you got this guys details?
rob
Originally Posted by nigel b
have you tried a new gasket?
rob
that is exactly where mine is leaking from. leaking from the compressor housing and the oil is all over the oil return hose so the gasket must have gone aswell. but mine is leaking proper, i mean topping it up nearly everytime i have to drive it but its my only car so have no choice.
after reading that think i'll have to check the geeza that built the car didnt use the t2 oil return, i have a t3 fitted.
good luck with it though mate, let us know if it cures it
JoeyBoyden
18-08-2015 10:52 PM
