FAO Existing S8 ecu owners LINK RESTORED :)
Old 14-10-2006, 09:58 AM
  #41
space hoppers
space hoppers's Avatar
he has used it on my car found the fault in seconds the dosey twat who owned the car [me] left the main plug to the block off. i gave sheady that tester from simon i think
Old 14-10-2006, 10:26 AM
  #42
Jay,
Sponsor
Jay,'s Avatar
Originally Posted by RS500/364
whats is this ABS checker i know sheady had one form somewere
u run the car at 30 MPH and checs the sensors and stuff but the firm went brankrupt
mate it a bit more clever than that its something simon made about 8/10 years ago it does 35 checks on the system valve block pump even the light test on the dash as for the company goin bust fuck knows who cares
So not a simon clone just one of these plastic case with lights i think?
nope its a proper device mate tells what test its doin i.e led tells what test ur on ,push buttons to set each tests green and red buttons for pass and fail . ive just arranged to buy it think its guna useful
Old 14-10-2006, 12:31 PM
  #43
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
Right, installed the windows based platform, i have to run a USB to serial converter as my laptop dont have a serial port
Every time i try to connect i get the message "ECU COMMUNICATIONS: no reply [2]." Is this due to the USB / serial converter. Tried all the COM chanels, bit rates, buffer sizes and Fifo stuff.
Bri.
Old 14-10-2006, 05:34 PM
  #44
kjc300
kjc300's Avatar
Dell Inspiron 7500 PIII ???
W98SE
com port - YES
usb serial adaptor - YES
pcmcia serial port - NO
Old 14-10-2006, 05:36 PM
  #45
kjc300
kjc300's Avatar
Advent 7065 P4 3.06 ghz
XP Home
usb serial adaptor - NO
pcmcia serial port - YES
Old 14-10-2006, 05:37 PM
  #46
kjc300
kjc300's Avatar
Bri.
What operating system you using Bri??
Old 14-10-2006, 05:40 PM
  #47
kjc300
kjc300's Avatar
My pcmcia to serial is one of these......
http://cgi.ebay.co.uk/PCMCIA-to-RS-2...QQcmdZViewItem
Doesn't seem to work on W98SE at all, does on XP.
Old 14-10-2006, 05:43 PM
  #48
*Bri.4.b.Cos*
Bri.
On windows XP
Bri.
Old 14-10-2006, 05:46 PM
  #49
kjc300
kjc300's Avatar
my usb to serial wont work on xp!!
But the thing I posted above does!!
Old 14-10-2006, 05:57 PM
  #50
*Bri.4.b.Cos*
I'm not sure what expansion slot is on my laptop, wether it be PCMCIA or Card Bus. Its a Dell Inspiron 1300, any idea's?
Bri.
Old 14-10-2006, 06:11 PM
  #51
kjc300
kjc300's Avatar
That has an "Express card slot" Bri
whatever one of those is!!
Old 14-10-2006, 06:32 PM
  #52
RS500/364
RS500/364's Avatar
Bri.
Sure my one was PCIMAC cardbus 32!!
Old 16-10-2006, 03:28 PM
  #53
ECU Monitor Enthusiast
Thanks to all that have helped.
This is only a test version and I did expect some initial problems
as the original windows program worked so well in previous tests
and I was sure if I touched it, it would break.
I am very close to completing this software will be available soon
with ALL new features activated.
And off course it will be FOC to anyone.
If all goes to plan, ecu's will be back on sale soon when all issues and
updates are complete.
These will be sold/marketed by another company that is well known
and respected.
I hope to post up another update very soon as a teaser and I will enable
all the menus for you to try.
Old 16-10-2006, 03:37 PM
  #54
Fiecos Dan
Fiecos Dan's Avatar
Good stuff Simon,
When will launch controll and data logging be available?
Old 16-10-2006, 03:43 PM
  #55
Danny,
The data logging will be available very soon.
This will be done in the ecu . - NO PC needed (up to 1 hour limit)
and also, with a PC where the limit is the size of your hard disk.
Launch control is a different matter.
As I dont have a working car at the moment, I cannot test it works correctly.
Therefore, It would not be right for me to release it as if it breaks
someones car then I would never hear the end of it.
However, If you are up for some "own risk" testing in the future....
Old 16-10-2006, 03:46 PM
  #56
Fiecos Dan
Fiecos Dan's Avatar
Originally Posted by SECS
Danny,
i'm up for that, as long as your around on the phone while i'm testing, to assist if any problems.
Old 16-10-2006, 06:06 PM
  #57
*Bri.4.b.Cos*
and respected.
Will this require any hardware modifications to the ECU for the new function's ie, ALS, data logging?
Will the dash board option have analogue guages for quick glance with user defined danger zones, maybe an audiable alarm
Will the output tests have the ability to fire the coil, injectors etc
Sorry for all the questions
Keep up the good work Simon
Bri.
Old 16-10-2006, 06:11 PM
  #58
Bri.
No mods required for ALS or data logging. Only software upgrade needed
which can be done by yourself.
Dash board has both analog an bargraph style gauges.
No audible alarm but thats a good suggestion.
The output tests will work as they do at the moment. So yes.
Old 16-10-2006, 06:33 PM
  #59
kjc300
kjc300's Avatar
Any pics of the dashboard set up yet Simon??
Old 17-10-2006, 05:55 AM
  #60
Jay,
Sponsor
Jay,'s Avatar
on face value how easy is that software to use
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
DixieTheKid
14-09-2015 09:04 PM
Tank Mike
14-09-2015 03:56 PM
Quick Reply: FAO Existing S8 ecu owners LINK RESTORED :)
