Water Injection - Who uses it?
Sounds good Mike.
Do you find it makes a difference, I suppose you dont really realise as its more of a precautionary thing?
Do I get it or not..........
hmmmm
hmmmm
Caraholic
Originally Posted by Stu.H
Sounds good Mike.
hmmmm
hmmmm
this kits just been fitted to my ecossie BUT (please allow mike R a weeks delivery as he can be a bit slow shipping it)
If you are using very high Boost use the ERL Pump & not the Flojet, ive been there & done that & with Long Periods on the throttle the Flowjet got into a non-cope position. The Higher pressure ERL cured the problem completely. We are talking 2.5bar sustained.
Im stating Tested facts not having a go at Mike R.
Rod
Rod
Caraholic
Rod
Rod
You're getting confused with the old Flojet pump, which needs to be shimmed up to cope with the pressure requirements of a big turbo (which you can do), or ALTERNATIVELY, I now ONLY supply the Flojet pumps with the correct pressure rating in the first place (a lesson learned as they say ). I think you will find that 6.8 bar pressure is more than adequate to cope with you paltry 2.5 bar sustained boost .
The postage on the tiny fittings is as much as a padded envelope and recorded delivery costs, so £1.50 .
Rod
Rod
The old Pump was 50psi ( 3.5bar) so Mike has solved the problem with the new pump, it sounds the answer & is more robust than the ERL.
I was just passing on my now out-dated info.
Rod
I ran with water injection for ages on my S2 and although it's still in place and ready to go it just hasn't been needed on it since I fitted the Pace front mount intercooler.
Might take it off and fit it to my Fiesta though as the chargecooler doesn't seem able to cope
Pictures are now added as well .
expected better frm a bufty like you!!!
so i wil now post better quality
