iscv help please
Old Oct 6, 2006 | 02:46 PM
rsdene's Avatar
rsdene
Default iscv help please
hello, used the car last night without any problems, come to use it this morning and the cars just revs @ 2k all the time
i changed the iscv with another one i had and it does the same is there any thing else that could cause a similar problem??
or do i just have 2 faulty iscv's??
thanks alot
Dene
Old Oct 6, 2006 | 02:49 PM
kjc300's Avatar
kjc300
Air leak somewhere - inlet manifold gasket, dump valve pipe popped off??
Old Oct 6, 2006 | 02:53 PM
rsdene's Avatar
rsdene
pretty sure theres not, but i will check! thanks alot for the suggestion. most appreciated
Old Oct 6, 2006 | 02:55 PM
kjc300's Avatar
kjc300
Maybe even check the throttle is returned to the correct place, not binding up etc!!
Old Oct 6, 2006 | 04:35 PM
jon@work's Avatar
jon@work
check you've still got an idle speed adjustment screw in the bottom of your throttle body
Old Oct 6, 2006 | 04:54 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine has done this twice since the colder weather has kicked in,i just blipped the throttle and it idles fine .
Old Oct 6, 2006 | 05:00 PM
ECU Monitor Enthusiast
Faulty TPS sensor
DixieTheKid
11
Jun 6, 2020 11:20 AM
RSmark84
Sep 13, 2015 01:29 PM
cozzy jeff
Sep 12, 2015 04:32 PM
muffster
13
Sep 3, 2015 09:40 PM
Cosnada
Aug 27, 2015 09:15 AM
