high power on high C/R turbo engine
#42
Former Sponsor
are the latest foci not 11.1?
i will find out in an hour or so when m-sport finish for the day.
mike,mines not a wrc car but it has a 36 tooth pulley on T6.
#43
DEYTUKURJERBS
Focus WRCcar or Focus ST?
Focus ST is 9:1 compression.
Would expect nothing less from a low boosting 2.5litre engine pushing 225bhp.
Almost suprising its not more TBH.
#45
i know i can go away and build my engine to suit and as tried and tested lower comp makes for easy power with boost and reliabilty, i just wondered why others can make the power on pump fuel ,and then maybe saving Ł500-600 its gona cost to get my C/R down.
evo fq's have high C/R iirc too?????
#46
Caraholic
#47
#49
You can probably get away with low 8s, but you still need to lower the c/r from 9 .
basically fooked up on the build when a valve spring broke, i had to take the head off and been a bit skint opt'd for a cheap 1.2mm gasket instead of the Ł100 1.9mm cometic. a long with some extreme head skimming by the twat of a engineer, led to the high C/R
#50
Caraholic
Anyway, I can't be arsed to sort the scanner out at the moment, so here are the figures for a top-spec WRC engine (Carless 102RON) and Ł3500 of IHI turbo, solid lifters, world rods / pistons and restrictor. As I said, single figure boost at high rpm .
Goes revs, torque (lb ft), bhp, boost
2040 : 157.2 : 61.0 : 6
2520 : 331.1 : 158.7 : 22
2990 : 475.8 : 270.5 : 36
3550 : 460.0 : 310.5 : 34
4030 : 412.9 : 316.4 : 29
4510 : 371.1 : 318.2 : 22
5020 : 334.8 : 319.5 : 18
5510 : 297.2 : 311.4 : 14
6010 : 270.5 : 309.1 : 12
6500 : 241.3 : 298.2 : 10
7030 : 215.0 : 287.4 : 9
#53
...but Mike...you have to say thats a reliable engine...and i'd like that in a road car with v-power 99ron the drivability would be fooking ace.....and i you could get away with near that boost on a road engine too plus the odd track because no way is anything as demanding as a rally stage imo....whats the compression 9.5-1?.....
You need no more power than that in reality for road applications!
#55
Caraholic
I've been out on the road in Harvey's old FINA Grp A car, and although the punch off the roundabouts is devastating, once on the open road the engine NOTICABLY runs out of puff, to the extent that my 343bhp / 403 lb ft T34/0.48 a/r car felt nicer to drive. The rally engines are built for low down pulling speed, for drive out of the corners. I would not want a rally engine in a road OR track car. Change the parameters to a track or short sprint car, and yes the above engine would be ideal.
Also given your current engine, don't you feel the tiniest bit hypocritical making the above comment?
#56
I know of a 2 litre YB running 32 psi and over 600 bhp dyno proven
using pump fuel and its CR 8.5:1
(NO NOS)
Still running after 2 years and used in anger most days..
There is MORE combating CR requirements than boost and fuel type.
(NO NOS)
#57
Caraholic
(NO NOS)
(NO NOS)
#60
Mike who cares about the ignition..that car Simon refers to would be staggering.
I didnt choose the comp ratio in this car It is horrible off boost...dont get me wrong it runs sweet as but its just lethargic...still,not as bad as my 7-1 engine
I want drivability but i wont change this engine for the world as the nothing then too much is fun ...I am however tempted to buy another cossie to bung my other engine in and use as a everyday car..not sure yet
#61
Here is the map...
RPM Index left to right
500,1000,1500,2000,2500,3000,3500,4000,4500,5000,5 500,6000,6500,7000,7500,8000
BOOST Index Top to bottom(Tenths of PSI)
-150,-100,-80,-40,+0,+40,+80,+120,+160,+200,+240,+280,+320,+360,+ 400,+440
330,200,200,200,160,160,230,240,220,190,180,150,14 0,100,100,80,
320,200,200,200,200,280,230,240,220,190,180,150,14 0,100,100,80,
240,200,200,200,250,280,230,240,220,190,180,150,14 0,100,100,80,
250,250,250,250,250,250,230,240,220,190,180,150,14 0,100,100,80,
250,280,280,280,280,250,250,250,220,190,180,150,14 0,100,100,80,
250,350,310,250,250,260,250,250,230,190,180,150,14 0,100,100,80,
160,300,250,250,250,200,250,230,210,190,180,150,14 0,100,100,80,
160,300,250,250,250,250,240,220,200,190,180,150,14 0,100,100,80,
160,300,250,250,250,250,240,220,200,190,160,140,13 0,100,100,80,
160,300,300,300,300,300,260,230,220,200,190,170,15 0,100,100,80,
160,300,300,300,300,300,260,250,220,180,170,140,13 0,100,100,80,
160,300,300,300,300,300,260,250,230,190,170,150,13 0,100,100,80,
160,300,300,300,300,300,260,250,240,200,170,140,13 0,100,100,80,
170,300,300,300,300,300,260,250,240,200,180,150,13 0,100,100,80,
160,300,300,300,310,310,260,250,240,210,190,160,14 0,100,100,80,
160,300,300,300,310,310,240,240,230,210,190,170,14 0,100,100,100
Values in tenths of degrees BTDC
This map was the first rough dyno map that did a power run.
#63
Former Sponsor
Originally Posted by TF Rallyesport
thats off harveys computer isnt it?cannot remember which car it was in but was looking at that readout when i picked mine up.
Care to retract your 2.0 bar held comment?
perhaps my guage is faulty,its only a shitty stack one.
#67
i would think tho that your ikle fiesta against my 1400kg cav is gona have less in-cylinder pressures?????? or doesn't it work like that ?
#68
Caraholic
#73
GARETH T,
Dont have a AFR map as its with the owner on his dyno sheet.
It wasnt overlly rich from what I remember.
As I said, OTHER factors make high CR possible. (Mechanical bits)
#75
GARETH T,
ph mike im on your side aswell
#76
no i have an escort,here it is in macdonalds drive through mid rally!!we were hungry,markk in the background in the chase car.
#77
(NO NOS)
(NO NOS)
