Whot size is a 4x4 cosworth ARB SORTED CheeRS :)
28mm
you'll need to get the proper 4x4 one as they have different ends and shapes to the 2wd cars
don't get a granada one as they are different too
it all affects the way the fornt end is set up, i put a thicker granny cossie one on mine and although the turn in was great, in the straight ahead position it was tramlining to fuck
dojj Thats it 28mm I have a set but got nothing to hand to messure them There the wrong colour tho so got to order some more
Im running Compression struts which are off my m8s car his back end is all poly bushed and got a front end set but the ARB bushes was wrong and im still waiting for them to be replaced but not having much luck with getting them its been wks now
So i have found someone else that can do me them in the right colour Yellow Just he wanted the size of the ARB
CheeRS
CheeRS
the actual arb to body bushes vary between the cossie and the non cossie cars
you can get a 24mm and a 26mm arb as well, but it's the actual clamps that bolt into the chassis rails which can also vary in size
the other thing to remember is that the outer tca bushes are all the same, the inner ones vary from a 10mm to a 12mm depending on which car you have (the xr's vary between the 2 but cossies use the 12mm)
there are also different sizes on the granada on the rears, but thats a whole differnt story
as for measuring them, have you got a set of vernier calipers?
no?
then just get to bits of right angle metal (set squares or the like) and put them around the arb (assuming it's off the car)
mark where the squares overlap each other, take them off, put them on the desk and line them up again, then measure the width where they meet up
no?
sridgett
18
01-08-2015 08:49 PM
