are they the same
formerly beefy-rst-2
1.6 cvh head from a fezzy xr2i (efi)
and a s2 rst head ??
apart from the obvious inlet differences ??
thinking of going efi over the winter and a local breakers had a cpl in ??
efi and MFI heads are different mate, however if when you run the efi head you run the efi inlet manifold and a genuine ford exhaust manifold gasket you will be fine.
Will bolt up just the same, however just as you have allready mentioned the port shapes are different.
Originally Posted by Dicko&Sarah
beefy i thought you have just had a brand new engine rebuild just done
and ?????
whats that got to do with me going EFI over the winter ?????
efi and mfi are different
only ports are diferent though it wil bolt on just the same
the valves between a frst,s2,xr etc are teh same, its only the s1 that had sodium filled valves so i was told
but the black top cfi engines 1.4cvh are different on teh combustion chanbers on teh heads and different valves but ive heard these are the best heads to use when going efi but need to have a lot of machining doen for it to work
Now then beef you no all you have to do is ask mate. s1 had sodium filled exhaust valves did'nt have them in s2. dont need to change ya head and inlet manifold to go cozzie management mate ive already sorted that probelm...
nice one fella . speak to u soon bud
and sara/dicko
thats the fun in it isnt it ??
ohh u got ur fixed yet ?/ ooooh sooooo negative sweetie lol
must be the pregnancy lol
