brain box...quantum science....
im lookin for the best and easiest to understand description of what Schrodinger was trying to tell us with his cat theory..
Schrodinger s cat........lets discuss....lol
Originally Posted by GARETH T
me and phil m was talking about this about a week ago
he fonud a cracking website
i know you posted this too be smart
wait for my IQ thread tomorw, im going to post a brain buster every day just for a laf, keeps my brain workin aswell lol
if you can explain why the speed of light is the only constant of our universe ill buy you a pint
The relative speeds depends on the observer, and that relative speed will always be the same. If an observer witnesses light travel past from stand still it will be seen to be travelling at the same speed to an observer, to the extreme, travelling with the light. The quicker the observer travels, the slower time will be, although it will appear normal. So at stand still time will be as normal, and for the observer travelling at the speed of light time will stop meaning it doesn't matter anyway
Now the others physical properties are not constant for various reasons, speed of sound affected by speed of travel (doppler effect), weight takes into affect gravitational pull so depends where you are, etc etc
Done
Done
Done
whats this gravity your talking about?
0/10
Because its speed is not affected by the environment in which it is travelling, unlike anything else
Oh well, I guess if you didn't have a constant somewhere, you wouldn't be able to do many equations
[quote="MB7201"]
can you then explain to me how you would be able to see anything if you were traveling at the speed of light?
thus, the observer would not be able to observe anything
explain
explain
find the childrens section
look up dr seuss
having googled the cat business, you have to propos that the cat will be dead in the time it takes the air to run out in the vacuum filled steel chamber
this will be a lot sooner than the radioactive substance (which could also be porposed woudl kill the cat) runs out and breaks the cat killing capsule with the cat killing acid in it
to presume that the cat will be alive indeffinitly is a falicy because you have sealed the cat in it's doom when you have closed the chamber door
if you were not to open the door within a matter of minutes the cat would certainly perish
(all this is assuming that there is a small bax the cat is going to be placed into, not a big steel room the size of an oil tanker which would give the cat a lot longer to live because the air would be more sustainable and it also doesn't prusme that there would be food and water left inside for said cat to nourish itself on for the duration of int experimental incarcaration)
[quote="dojj"]
explain
i dont really understand your question,,,of cuase that statement is hypothetical and something we could practice
explain
got to be able to do it......
look up dr seuss
explain
0/10
I was thinking one possible way around this. Light has been shown to take the properties of both a wave and a particle. So with this we see the properties of the wave come in but in reality the particle is unaffected and still travelling at the same speed?
Well, I havnt actually been to the speed of light so don't know exactly
no google'iing aswell simon
I dont know what you mean..... Wiki is better for this sort of stuff
Nope, light will accelerate away from you at the speed of light, regardless of your velocity. To you, everything seems normal
Relativity - its a headfuck
i went to winkopleadia and read about it there
seems a nice and simple eplanation that you have to accept the feline will un out of o2 before it's going to get killed by the ration running out and killing it via lukeamia or the like
Nope, light will accelerate away from you at the speed of light, regardless of your velocity. To you, everything seems normal Clin d'oeil
Relativity - its a headfuck Surpris
_________________
don't get that at all
_________________
