Help Fitting Grey's Needed....
Old Aug 23, 2004 | 08:53 AM
AlexD's Avatar
AlexD
Post Miester !
Default Help Fitting Grey's Needed....
Got to fit a set of grey injectors to a mates car this weekend, can someone
tell me how they fit them . I know someone had a picture of an
injector with the fitting kit on it, any chance someone can post that up???
Al........
Old Aug 23, 2004 | 08:57 AM
GARETH T's Avatar
GARETH T
laid out in order aswell
Old Aug 23, 2004 | 08:59 AM
AlexD's Avatar
AlexD
Post Miester !
Cheers Mate, Just the job !......
Al...
Old Aug 25, 2004 | 07:00 PM
AlexD's Avatar
AlexD
Post Miester !
Right, went round to fit the greys and got stuck
Ok thats what it should look like yea??
Our injectors have a blue shroud on the end ( not I don't mean the covers )
Am I supposed to pull them off cos I've pulled as hard as I like to and they don't move?
Part no on them is 0 280 150 403
Have a look!
Someone help please!!
Thanks
Old Aug 25, 2004 | 07:01 PM
TIFF's Avatar
TIFF
Chasing Radders
You have to cut them off, but mind your fingers
Old Aug 25, 2004 | 07:50 PM
AlexD's Avatar
AlexD
Post Miester !
Right so you cut off the entire blue thing so there is none left at all
Old Aug 25, 2004 | 07:54 PM
Cosworth4388's Avatar
Cosworth4388
yes slit it down the side and then pull it off
remove all of the blue m8
Old Aug 25, 2004 | 08:59 PM
alan rainbow's Avatar
alan rainbow
and dont bother with the yellow bit on the end as well as you get a better spray patten
Old Aug 25, 2004 | 10:13 PM
AlexD's Avatar
AlexD
Post Miester !
Cheers for the replies . Will sort it out now.
Al...
Old Aug 28, 2004 | 09:45 AM
AlexD's Avatar
AlexD
Post Miester !
Right, I shoul have this right?
Then why do I have this??
The top half seem fine (although the top ring is too small to go on )
but the bottom half I've
A. Instead of a nice snug fitting metal washer I've got a plastic ring which is much bigger that the diameter of the metal end of the injector
B. I have 2 o rings instead of one
Anyone help or have amber just sent me the wrong fitting kit
CheeRS
Old Aug 28, 2004 | 09:56 AM
CraigN's Avatar
CraigN
the top pic is what it looks like after the kit is on
the top ring is not to small
just an absolute fucker to get on
Old Aug 28, 2004 | 10:05 AM
AlexD's Avatar
AlexD
Post Miester !
I know the top pic is with the fitting kit on Craig and thge top half I'm not worried about as a bit of brute force and ignorance will get the top ring on but the lower half of the fitting kit seems all wrong
The pic show a metal washer, rubber o ring and the yellow pintle
My kit has no metal washer, a plastic ring which is to big for the shaft and 2 o-rings?!?!?
Old Aug 28, 2004 | 10:08 AM
CraigN's Avatar
CraigN
hmmmm
stu helped me out when i needed a single washer to replace one i had lost
give him a bell top man
Old Aug 28, 2004 | 10:12 AM
Cosworth4388
M8 a lot of kits have the grey plastic ring (which is just a spacer)
that what i got with mine
and the top ring i think i had to tap it on with a 8mm socket
just make sure the beveled edge faces the top
The kits do normally have extra rubber "o" rings
Old Aug 28, 2004 | 10:27 AM
3doorPete's Avatar
3doorPete
If I was a Bristol based Cossie rebuilder - I'd be rubbing my hands togethor right about now!!!!
Old Aug 28, 2004 | 11:28 AM
we havent got no bristol based cossie buiders maybe thats the problem
Old Aug 28, 2004 | 12:48 PM
gurnE's Avatar
gurnE
And why exactly is that??
Old Aug 28, 2004 | 02:41 PM
3doorPete's Avatar
3doorPete
If you're fitting greys, I'm guessing its a 380bhp+ engine.
Personally if I wasn't 100% sure about what I was doing, I would bite the bullet and spend a few squids and travel a few miles to get it done by a pro.
If running greys there is probably a good few quid sunk into the engine, plus if it was my mate I'd worry about something me messing something up, or damaging the injector causing a melt down.....
If it was a straight job and looked how the picture said, then fine, but it looks like it's not. Hope it all works out - but IMO could end up with a rebuild, hence the comment.....
Old Aug 28, 2004 | 05:36 PM
gurnE's Avatar
gurnE
You know absolutely nothing about Alex's or Alex's friends knowledge and experience so kindly keep your snide comments to yourself
Having never fitted greys before and as they do not have the conventional euro clip fitting and we are dealing with fuel in a hot engine bay under 3-4 bar pressure do you not think it wise to ensure that they are fitted absolutely correctly???
I am a qualified mechanic and just because I've not fitted greys before does not mean I shouldn't attempt it, it simply means I should ensure I know exactly how they fit before fitting them.
It's not just a case of sticking in a chip, injectors, winding up the boost and hoping for the best.
Alex knows that, who are you to assume he doesn't??
manuel boeckx
13
Oct 3, 2015 02:29 PM
john_3.0s
Aug 16, 2015 06:40 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
CrOwSoN15
Aug 14, 2015 06:52 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
