306 central locking???help!
Old Sep 10, 2006 | 08:32 PM
turbo terry's Avatar
turbo terry
Default 306 central locking???help!
My 306 central locking has packed up, all lock and then unlock again straight after.
was guessing a solenoid how do i check ???or check for open circuit?
any help muchos appreciated, i havn't a clue!
Old Sep 10, 2006 | 08:35 PM
Shings's Avatar
Shings
Nope guess again..
Wiring on the doors have problems as the loom is too short.
You can buy a kit to fix the problem - its very common on 306's
Its about 90 quid I think and isn't the nicest job to do.
Jake
Old Sep 10, 2006 | 08:42 PM
turbo terry
ok cheers!
So wire from the lock to where it is connected at the door has prob broken?
How do I check which door it is? or just check em all!?
Thanks bud!
Old Sep 10, 2006 | 08:44 PM
Shings's Avatar
Shings
I dunno.. all I know is they have a loom issue on the front doors and you buy a repair kit which needs fitting- I believe its a door off job..
The repair kit is longer and solves the problem
It stems from the fact 306 doors open so wide.
Jake
Old Sep 10, 2006 | 08:47 PM
MAD EVO 4's Avatar
MAD EVO 4
Old Sep 10, 2006 | 09:01 PM
Andy_R's Avatar
Andy_R
The plastic buttons that move up and down as you lock/unlock the door have a habit of sticking causing the central locking to lock/unlock as you describe.
An easy fix is to simply remove them(I did and the problem was cured)....worth a try & if it works its saved you £90.
Old Sep 10, 2006 | 09:50 PM
gup's Avatar
gup
peel back the rubber cover on all the wires leading into the doors then this will tell you if a wire has broken or has been cut i had one like this at work and it ended up being the wires in the boot by the hinges getting strapped and shorting the circuit out
Old Sep 10, 2006 | 11:16 PM
AndyBlackFRST's Avatar
AndyBlackFRST
As said above... The wiring inside the rubber joining the wing to the door has a common fault with wires breaking.
Old Sep 11, 2006 | 07:05 PM
James's Avatar
James
Yup, replacment looms are a arse to fit as none of the colour match up either. Door off job really, but removing the doors are easy as so no worries there.
Old Sep 11, 2006 | 07:42 PM
turbo terry
cheers, i'll investigate further when i get a chance.
fook paying 90quid though, i only paid £100 for the car
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
