earth points diagram
hi folks, does anyone have a picture or diagram with the earth ponts ina 1989 2wd saph? is there an earth connected to the dashboard lights, as alll my dash lights have gone off,
cheers
Luke
cheers
Luke
Also worth checking the dash board dimmer switch
Pull it out and connect the two wires off the back of the switch,should get dash lights at there brightest then
Gracey means on the back of your set of clocks
Gracey means on the back of your set of clocks![Top](https://passionford.com/forum/images/smilies/smile011.gif)
whats the best way to get to the back of the clocks then?? the lower dash pannell?is it just unscrew and have a feel around??
Originally Posted by lukeytheduke
cheers mate, so do i connect the wires when the engine is running yer??
im crap at electrics
Easyiest way to get to back of clocks is to remove them,can't remember off hand how many screws etc there is,but you need to remove the cowling that sits over clocks first and the steering column surround IIRC
