MAJOR ELLECTRICAL PROBLEM?
Old Aug 30, 2006 | 10:14 PM
lukeytheduke's Avatar
lukeytheduke
Default MAJOR ELLECTRICAL PROBLEM?
Hi all, need your opinions on a problem on my car,
first of all the background of my car, its a 1989 2wd saph, only mods are stage 1, chip air filter etc etc
I was driving home and i suddenly lost all lights on my dash. Here is a list of strange things that happened while trying to drive home
1. no lights on dashboard, but ecu lights like door open lights and water and petrol lights on as usuall then turn off as usual.
2. Phoned AA, but they sent out a sub ciontractor- PRICK- PJM RECOVERY!! He just took out every fuse to see if its blown, which it hasnt, then he just said ti drive home with no lights on my dash
He thought it was the bulb in my dash blown but it was not this.
3.The speedo, rev and tempreture gauge would not move at all when reved the engine from standing
4.When i drove home still with no lights on but the BATTERY light was on all the way home
5. The CLOCK reset itself to a random time
6. Whem driving home the DOOR OPEN lights were ON but faded
7. When BRAKING the low fuel and water lights would come on
I know cossies break down but im thinking this is some kind of short circuit which explains the strange lights etc etc
I phoned the AA up to complain about the service, and they took this attempted fix of my list of cal ous as you only get 5 for free per year!
What a crazy evening, any ideas much appreciated
Luke
Old Aug 30, 2006 | 10:18 PM
ECU Monitor Enthusiast
Check the big terminal juction strip on the battery positive.
Make sure all wires are intact and in good condition and that all the
terminals are tight.
Also, check your fuse box hasnt melted internally.
Old Aug 30, 2006 | 10:19 PM
lukeytheduke
what do u mean melt ineternally??what should i be checkin for as the fuse are all ok??
Old Aug 30, 2006 | 10:22 PM
melzieann's Avatar
melzieann
check the wiring loom mate where it passes down side of o/s/f chassis leg next to turbo due to the 2wd mainfold it tends to burn all wires, and can set car on fire so becarefull
Old Aug 30, 2006 | 10:24 PM
lukeytheduke
lmao
On fire!! what doe sthe wiring loom look like then? From a beginners point of view please!
Old Aug 30, 2006 | 10:30 PM
melzieann's Avatar
melzieann
The loom runs under the Abs pump, may need to take heat sheild strut brace if fitted off,it is a cylinder shape wrapped in black electrical tape, i had the same problem when i changed to a 2wd mainfold and a mate of mine had the same common apparently
Old Aug 30, 2006 | 11:37 PM
Tobester's Avatar
Tobester
Might be worth checking the main earth connection/strap in the engine bay - these can and do corrode producing bizarre electronic faults - not sure where it is in a Cossie, but you'll find it somewhere on the bulkhead. Good luck!
Old Aug 31, 2006 | 07:40 AM
lukeytheduke
any ideas where the earthing connection is on my 2wd saph??
cheers
luke
Old Aug 31, 2006 | 09:58 AM
CosKev3's Avatar
CosKev3
cheers
luke
Main battery earth points are on battery tray just infront of the battery,from battery to bell housing of gearbox,on front of inlet manifold where throttle cable bracket bolts on,and one just in front of header tank bolted to front panel
There the ones I can think of off the top of my head m8
Old Aug 31, 2006 | 10:33 AM
lukeytheduke
cheers fellar always helpfull as usual
Old Aug 31, 2006 | 03:27 PM
lukeytheduke
any other ideas??
Old Aug 31, 2006 | 03:41 PM
dojj's Avatar
dojj
Resident Wrestling Legend
sounds like the pcb in the back of the dash has gone
if the battery light is on that means the battery isn't getting charged so i'd be carefull of how far you go in it like it is
all the dash lighting etc is controled by the dimmer switch so thats the first point of call
after that, pull the dashout to see if there is power going to the back of it, i'd assume not which is why nothing works on the dash but other stuff (like the glovebox) do
the clock is in with the same sort of curicit to that explains that one
other than that, there are a 1,000,001 things tht can go wonrg
Old Aug 31, 2006 | 04:21 PM
fordsportjay's Avatar
fordsportjay
check the dimmer for the lights-had one of these go a few years ago on a cossie and the fucker caught fire-melted all the loom.
Old Sep 1, 2006 | 11:40 AM
dojj's Avatar
dojj
same things happened to the granada i got off of while, taking it apart it seems that the dimmer siwtch has melted, resluting in things not working
Old Sep 1, 2006 | 11:48 AM
lukeytheduke
so how do i check the dimmer switch is working, pull the swithc out and connect the two wires behind it yer??, if that doesnt work, hopefully the dash switch has fallen out, and if that dont help check the connections under the fuse box, in that order
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
