hydraulic clutch conversions
when converting a car to run a hydralic clutch, what maths need to be done when it comes to master/slave cylinder sizes and pedal travel/pedal ratios?
wanna be converting mine soon, its a focus gearbox, ill more than likely just use an integral willwood master cylinder (with the reservior build into it) but unsure what size i need to use and what the pedal travel needs to be to give me the fluid siplacement and therefore right movement in the clutch slave cylinder/release bearing.
anyone shed any light on the subject?
Square the diameter of the two cylinders, thats the ratio of movement from one to the other mate.
If in doubt go too big rather than too small as you can always alter the point of leverage to make it move less for the same movement on the pedal but you cant make it move more than fully travel, if that makes sense?
mk3ste
17-10-2021 10:09 AM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
