4x4 saff converted to 2wd, whats needed?
Basically i`d like to no what you need to convert a 4x4 to a 2wd, i no some things but not all, can someone give me a list of whats needed please
cheers
cheers
To do the job properly you would need all of the 2wd running gear,fairly easy conversion to do,you need to get a prop made and fabricate a gearbox mount for the drivers side of the tunnel.....
Give me a shout if you need any info.....
I will be taking some decent res pics of the underside of mine when it is finished and posting them up to help people who want to convert thiers in the future....
the rear prop is smaller so it will fit the escort.
if you are using the saff shell then a 2wd prop will be ok,no need to alter.
you change the rear beam to a 2wd one if you want a 7 1/2 inch rear diff, the 4x4 beam uses a 7 inch diff.
Originally Posted by NUTTIN RILLA
Excellent mate, why do you need the prop made, does the 2wd one not fit, do you change the rear beam too?
cheers
cheers
Cheers boys, i think i can source a donour car but i still wasnt sure of what to change over, its not a defo yet too, its for one of my mates, he`s got his 4x4 and kept breaking gear boxes so got a big tooth and i think 2nd is on its way out, he`s not had much luck and pondered the thought of going 2wd
cheers for the help, if he should go through with it i`ll give yous a shout if were getting stuck
cheers
cheers
I use my MT 75 and have over 400 bhp with no problems, and then you have the right gear stick and synchromesh on reverse too! I let you know when my gearbox breaks, and if it does i get a new one on the scrapyard for 150 quid.
I mate its who your thinking of, lol, its just a thought running round his mind at the minute, you no what he`s like, but the topic keeps coming up so i thought i would ask a bit about it first before he dive`s in
What you driving now mate? you going on sunday?
sound mate, hopefully i should be there in ma old steed, but it just depends how it goes, brakes, new fuel lines, mot, and tax before sunday, not alot really but im a lazy c*nt
jason_nike
18-08-2019 10:53 AM
lockie
31-07-2015 10:03 PM
