Braided brake lines...
garibaldi
can you use braided brake lines as an every day road car or not?IE from front to back underneath the car.
I was told that no i cant use them. I said okay no problem i will simply slide the braided hose over the top of the orginal lines as an effect that they are fitted.
He says on both options the car will fail an MOT. Is this true???
He will want to see them to ensure that theyre not rusty.If you cover solid pipes in a braided sheath he wont be able to tell if they are good or not hence a fail.If you run them inside the car you will be defeating the object of having them which i assume is to look nice.
garibaldi
I was told that you can get stainless lines but these are not cheap.
You can run stainless braided hoses under the car with no problems at all. I have done it for years.
As for the comment regarding keep hard pipes to stop a spongey pedal, WTF??? You get a less spongey pedal with decent braided hoses, as they retain there shape for almost there whole lifetime, whereas standard pipes corrode and standard hoses perish.
If you go from master cylinder to caliper, you have less potential for leaks too, as you have less joints to fail.
If you are running the braided hoses outside of the car get the ones that are plastic coated. Otherwise, grit gets in amongst the braid and can damage the brake pipe.
Originally Posted by Wardy257
Replacing the flexi rubber hoses with braided hoses can improve bake feel, replacing the metal pipes won't.
Get the hardlines made out of stainless steel tube
As far as I am aware braided lines are ok front to back etc....as long as they are well secured.....if you leave them free they car move about when you press the pedal and hence giving a spongey pedal.
All I read is people posting bollox...
Fluid will pass down a tube, the point of that tube beginning to expand under pressure is WAY WAY WAY above what your right (or left) foot could put it under.
Braided lines will NOT give you a worse pedal feel in that respect.
1st to 200 without NOS
I have braided lines, but have not finished building the car yet. I am not expecting a firm peddle.
As indicated on the Turbosport thread, it takes a lot more effort to make and fit copper lines. I may still use copper lines in some places, I have not fully decided.
Next time I am on the phone to M-Sport or Prodrive I will let them know that some guy who posts on turbosport who is building a Mk2 escort has crap brakes so they must stop the production lines of all WRC cars NOW
lol at nuts
all im confused about is... why do you want brake lines that "look good"
how often do you gather your mates round to lie on the floor and look under your car
garibaldi
Originally Posted by G420 DEL
lol at nuts
So why wouldnt i want my brakes to look good
The whole of my running gear is being powdercoated and stuff in 6 weeks time when car is taken of the road so its only natural that i dont neglect the fuel and brake lines.
anyway... my brakes aren't finished yet, and i went for all braided in the end so if they are crap then I'm blaming you Tony as clearly it will be your fault mate!
