Hard Drive help....(Now with link)
Following on from my HD failure thread the other day. I now want to replace the Hard-drive.
The current HD unit is a Western Digital Caviar SE 200gb SATA drive. The PC is a fairly recent Hewlett Packard 3.0Ghz job with 1gb RAM.
What should I replace it with? Do I need to get 2 HD's? Or can I be protected from this type of failure with 1 HD and a software package?
If you're looking for reliability, and consider that more important than cost, then I'd suggest looking into some form of RAID setup (Redundant Array of Independent Disks). RAID1 would probably be a relatively reliable, and not too expensive, choice......two disks, mirrored and linked to keep data the same on both, but if one disk fails, it can rebuild the info from the 2nd disk.
Obviously with that setup, you're looking at twice the cost for the storage space of one disk (ie. you'd need to buy TWO 400Gb drives to have "reliable" storage space of 400GB with RAID1).
Have a look at the VERY extensive document on WIKI, for a description of all of the different types of RAID setup.
RAID would be the best choice for reliability and higher grades are used in most servers.
RAID0 uses two disks dan, files are split over each and the systems reads from both disks at the same time.
RAID01 uses three disks, two used disks and one "redundant" disk which is the backup so when/if a disk fails the system rebuilds it using the redundant one.
Either that or a quality disk shouldnt really fail.
That's pretty much what I said...
RAID0 = 2 * 200GB = 400GB (using 200GB drives as an example)
RAID0 is not redundant, and a single disk-failure will cause massive corruption across the filesystem; it also doesn't have to be two disks, it can be as many as you want, but due to the lack of redundancy, there's not really much of a point in using it, to be perfectly honest.
RAID1 = 2 * 200GB = 200GB (again, using 200GB drives as an example)
The data in RAID1 is "mirrored" on both disks, so that if one disk fails, you can remove the failed disk and replace it with a brand-new disk, and it'll rebuild the mirror from the working disk. Again, as with RAID0, RAID1 isn't restricted to only 2 disks, you can use as many as you want, but if you're going to use more, you may aswell look into something like RAID5.
RAID01 (also called RAID0+1), that you mentioned, is a completely different setup again, from the above, in that you have (using six 200GB drives as an example), an RAID0 setup with three 200GB drives in both of the RAID environments, and then the two RAID0 environments are both encompassed within a RAID1 setup. This will give you 600GB of disk-space, but one disk-failure will cause an entire half of the array to need to be rebuilt (you won't lose data, because the remaining "working" RAID0 environment can rebuild the data across the RAID1 in the other RAID0 environment, once the failed disk is replaced).
lucid, thats not what raid1 is, youre describing a raid5 setup
imho dont bother with raid on a normal PC. the speed increases of raid0 are negligable even for hardcore gamers, and the extra redundancy of raid1 isnt worth the cost.
ive never seen a hard drive competely fail, only ones get "bad bits" on them, and a few files are lost (tiny ammount)
i'd rather save my money, and deal with a data failure later.
if youre really worried, back up and important data to an external device of some sort
i ran a sata raid0 for a while, i noticed NO performance gain
then one of the disks failed and caused me all sorts of grief![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
now i just run them all as seperate disks and have the drives mounted under the C root as seperate mount points
Jim
Jim
Testing the future
i had a hard drive fail on my home pc once. it was the one from the NEC factory, made by a company called quantum, and called a fireball - very apt, as a common failure for them was a component on the board burning out
i lost a lot of photo's when that happened, so now regularly back them up to dvd as they're so cheap these days. i also store important documents on my laptop and desktop, just in case.
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
40GB drive, just inside warranty still, sent it back to Maxtor (who now look after warranties for Quantum drives), and they replaced it with a brand-new 60GB drive!
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
OK, so it looks like I won't bother with the RAID thing. I will make more effort to back up my important stuff either to DVD or an external data storage device of some kind (more likely DVD).
So, one person has kindly cast an opinion on the Western Digital HD, preferring a Maxtor item over it. Any more opinions on which HD to use?
Hard disks are cheap these days, just get yourself a couple of drives and a raid controller (assuming your motherboard doesn't have it built in) and set up a mirror (raid1).
100gb+ is difficult to backup unless you own some form of LTO tape drive.
I had one of my mirrored 120gb drives fail 7 days before the 3 year warranty ran out. I got that replaced under warranty, put it back into the mirror and carried on as normal, didn't lose any data.
Go raid you stupid not to, most new mains board come with it built in.
Its the how good the firm ware on the array controlers is how good it handles a fail.
Jim, we have 18 TB San array at work we loose at leased one drive a month.
I have heard many a drive cluck its self to death. If you back up once and week mabe ok but just takes a month or so of I cannot be botherd to backup and you get a fail then you are fucked
jim raid 0 is not protection it helps with speed, Raid 0+1 is mirror, raid 5 is striping it only works if you have a min 3 drives. then there is another raid be fucked if I can remmber which can loose 2 drives.
on raid 5 you loose about 1/4 of the space to the raid stripping.
eg 3 200 gb drives will give you about 475 ish gb
Ive got a 300gig seagate barracuder in my 1 month old pc and its silent, and seems very quick
We stopped using Maxtor a couple of years ago as we had too many failing when relatively young, ie within a year. We only use seagates now and havent had a drive fail since (in desktop PC's)
For my home PC I've got a Gigabyte Mboard with on board RAID controller. I run 2 200gig SATA drives in a mirror.
Get on That!
Seagate or Samsung on a Sata-2 Raid array setup and you'll be rocking
or just do what i do and have 1 main fairly small master drive with just windows and ya programs install then a second large (sata drive) with all ya data on have used this setup for nearly 3yrs now and not 1 failure and is ultra fast due to the main drive only having what it needs on it
30GB drive for Windows/System/Programs, 120GB miscellaneous drive, and a 200GB drive for Games/Demos......not had a drive fail since the Quantum Fireball mentioned earlier blew up, and that was a good few years ago.
Sounds good. I did wonder about Seagate. So its out of the Seagate Barracuda and the Western Digital Caviar SE16 I reckon?
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
But yeah, i think thats your best bet for reliable data storage
PassionFord's crazy fool!
Personally I just use a small (80gig!) disk for my windows installation and then put all my programs and media on another disk. That way if Windows fucks up I can fix it and lose nothing, but if the drive itself failed I'd be buggered. As said though, a good drive should never fail. And mine is a 300gb Seagate Barracuda. No doubts about that drive whatsoever for me.
johnny, i know how raid works and what the numbers mean :P
i still dont think its worth bothering on a desktop PC. i mean what data are you going to lose if it fails? a few MP3s and some pictures of your car
its not like its business critical data you'd get on a company server.
if i had a disk fail i'd be a bit pissed off, but it wouldnt be a huge deal
