FAO: Engine GURUS - Turbo plenums
Would a tuned length inlet plenum with individual runners the same size (similar to an exhaust manifold in design) overcome the problems with getting completely equal charge distribution between every cylinder?
Here is a picture of a very serious quad GT47 blown V8 featuring such an intake.
DEYTUKURJERBS
In a word.
Probably
I remember mentioning this many many many years ago, on the RSBB probably, asking why its rarely done.
But TBH its the room, or lack of generally.
Only seen it done a few times in the above style, mostly on V8s, but 1 4cyl too.
Probably
Originally Posted by Stavros
In a word.
Probably
Probably
DEYTUKURJERBS
Dont forget too, its not just physical room for the pipes, but physical room to do up the fooking nuts that hold it on
I think its kinda one of those good ideas that are almost more trouble than they worth
Cheaper n easier to adjust the fueling per cyl than it is to make the airflow equal per cyl, even tho id much much much prefer equal airflow than trim the fueling as that seems like a mild bodge to me.
DEYTUKURJERBS
Originally Posted by GARETH T
did Paul hills do those wastegate pipes?
I thought that when I first saw em a few weeks back
I take it the V8 runs such big boost the wastegates never actually open, so the Paul Hills signature skinny EGR ALS pipes dont need to be used to make the car blow up
yes it would,,, the problem with tuned inlets is that they only work at one point in the rev/load range
very fancy looking thin though
you are right,, the inlet pulse does have a lesser effect on a turbo engine!
can see what you mean now,, thay have just gone for equal length! alot of work,, for nearly 0 gains!
All RB plenums suffer in varying amounts from unequal charge distribution (pot 6 esp runs lean) so I figured that the tubular approach would be a way to eliminate that and also allow for some other rejigging of the induction plumbing to try some ideas I have cooked up.
Ultimately you would need to experiment and test it.
Personally i suspect that intake will be less effective than a conventional plenum, but obviously if they have tried it and it works at the point in the rev range they want it to then they are probably going the right route.
I wouldnt advise just building something that looks similar and hope it works though TBH
Conventional plenum works really well, so i cant see the point in deviating from it that much.
Actually, if you look at the pic, despite all that very nice inlet pipework, you can see that the whole lot appears to go into a collector box (just like a conventinal plenium), so would that not negate the effects or possible benifits of long tuned inlet tracts?
cam is that your new engine for that yank tank your getting?
I don't know what you mean
Testing the future
Originally Posted by Porkie
Pokey
Whats it for? Is it for those mad tractors? or has Rod finally decided for one last go at Topspeed Record
is there a car that jay leno dont own?
i heard he thought he was the kiddy when he got his mclearn f1,,, drove it up his road,, and the guy next door has got one aswell
totally agree
Matt Baxter
16-09-2015 08:30 PM
