2.0 ZETEC TURBO
2.0 ZETEC TURBO
seriously considerin this conversion for my FRST, i currently have a hybrid t25 turbo, will this turbo be suitable for the 2.0 zetec?
earlier ones came with DOHC on the cam cover and the later ones zetec.. which one is the best one to use for this conversion and roughly how much do you think it will cost me if i did it myself
woudl want
decent cams ( kent, newman maybe??)
forged pistons
lightened and balanced (obvsiously send off parts for this, but roughly how much??)
also woudl i need new valves etc, i know the followers and stem seals woudl need replacing but would the valves need doing also??
if there is anything i have forgotten about a conversion like this please remind me
thanks
carl
woudl want
forged pistons
thanks
carl
why wouldnt i be revving hard chip?
i will rev till peak power which maybe 6500rpm??? or whatever it turns out to be?!
a t3 conversion may come up in the future when this one packs up
go for a T3 as a T25 will run out of puff VERY quickly and with the torque of the 2L you will not really feel any lag with the T3 on the car...and if you want most power...a Stage 3 T3 with a .63 exh housing and the car will be MAD quick!!!
to be honest it wont matter which zetec engine you go for (i have gone for the silver top) as you wont be producing MAD power where it might become beneficial to have the black top or even a ST170 engine!
before you think about the parts list....what power are you looking for and howmuch are you looking to spend?
bassboy
bassboy
power wise i dont want to be greedy, 230-250bhp will do nicely and i have read to make this power the zetec dosent need silly boost!!!
it would be more of a on-going project really
regarding price i could pick up the engine for £100
pistons i would imagine £300????????????
lightenign and balancing idont know how much?????
same with cams really!!!
what do you guys rekon?
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Forged pistons aren't an issue in the 2.0 Blacktops mate - the pistons in there are Mahles and will do 300.
Its the rods you need to address - you can get Eagle rods from ebay imported for around £500.
For that power, standard head, you can run a de-comp plate or skimmed pistons, or the better way is low compression pistons, either aftermarket or Calibra turbo pistons, a decent FMIC, OFAB management, good injectors, decent MAP, uprated fuel pump and a T3 turbo...... from the top of my head your there!
expect to pay around £1500 for everything...and dont forget new oil pump and water pump, timing belt kit etc etc
bassboy
bassboy
280...depends if your going ZVH or full 16v....if full zetec then the same as above using RS1800 inlet manifold and ERST exhaust manifold with a T3 and low comp pistons
but if ZVH, then stage 3 head needs to be added as well as cams!
bassboy
bassboy
With the correct turbo, charge cooling and management 280bhp can be had from a health zetec with no other mods than a thick head gasket.
If you only want 230bhp, i wouldn't bother thinking about changing the internals. Its a waste of money at that stage.
Stick with a healthy stock bottom end and spend the extra money on some mappable engine management. That way you can get the best out of your current set up and it is there for that monster power lump you may build in the future.
ITS on a FRST, wont the standard managment be up to the job? the 195 chip and beiges?
skimmed pistons are bollox, cracked shit loads on my zvh.
how can you define black top from silver top? every zetec i have seen has a silver cam cover??!!!
surely for what im after just lightening the standard rods woudl be enuff??
i woudlnt really want to risk standard pistons in there tho
carl
carl
believe it or not standard pistons should be ok with SPOT on mapping and LOW ACT's! the 195 chip wont be good enough as the management will need to be maped up for the 16v turbo as the fuel supply will be different as the air will be consumed in a different way....the amount of air one engine draws in air is completly different to howmuch another one does, hence the fuelling needs to be adjusted to suit
black top will have a black cam cover and normally comes in the later zetecs and known as a Series 3 engine...the water pump drive is slightly different to the series one and 2
if i were you and you want to play it extra safe, source a set of calibra turbo pistons for a CR of around 7.8:1 IIRC...could be mistaken
bassboy
bassboy
whats IIRC?
are the calibra pistons forged??
so couldnt leave my standard managment and get it set up correctly would need different definately?
IIRC - if i remember correctly
yes mate they are forged MAHLE pistons will EASILY take 300hp if not more!
u can leave your standard managament in but you just need to get it mapped by Stu at MSD or AHmed at Grove Garage
bassboy
bassboy
not really mate...you need you rods to be machined to suit the calibra pistons but its not a big deal...i think its just a matter getting hold of a set mate as they might be a bit rare
bassboy
bassboy
Use a thicker HG to achive the lower CR.
I wouldn't touch the rods unless you are confident you know what you are doing when it comes identifying stress raisers and radiusing to remove them.
As said before, with the correct ign timing and fueling cast pistons will be fine upto at least 250bhp.
However if you decide to run any old chip, designed for a CVH you probably will melt something!
garage19 whats HG? and how will that lower the compression ratio?
i have 195 chip at the mo with a 1.8 zvh conversion and it has not posed any problems?!
i have cracked many pistons tho (standard cast and skimmed) NOT WHAT I SPECIFIED when engine was built, but they fitted them anyway!! and they now keep failing
crack like a bitch
crack like a bitch
PassionFord's crazy fool!
Unless you really want to do a project then I'd say you'd be better getting a Cossie mate. It'll end up costing you similar money. If you can insure the FRST with the Zetec Turbo engine then I'd hazard a guess at you being ok with a Cossie.
As I say though, if you really wanna do a project then fair enough and best of luck.
I think there's info on www.turbo.me.uk about doing the ZT.
luke, why on earth would you want to do that for 215bhp?.. any of the standard zetec intakes will do over 300bhp.. megasquirt isn't capable of properly managing a turbo engine on multiple throttles..
Team HOTHOT!
well the big thing was i sold my normal inlet the day before as i had a N/A tb'ed engine and drove it twice before desiding to make a zt, i come across as custom inlet very cheap and when i went it pick it up it also seemed to be ITBs lol and i have been told mega squirt will be fine to map my car on
Well Luke.. whoever told you that is wrong.. the only way you could reasonably-accurately do a turbo car on ITB's in Megasquirt is by using a MAF..
No, it's nothing like that at all. Are you sure this manifold you've aquired is actually ITB's and doesn't just have runners that look like them?
Luke.. you can talk to those people, no offence, but the people I talk to actually write the megasquirt code.. so go figure..
You can do alpha-n in megasquirt, for n/a applications.. you can also do speed pressure (map).. the problem is, the amount of air flowing into an engine when you're using throttle bodies is not directly relative to the amount of boost you see at the map sensor.. eg, you can have the throttle open at different amounts, see the same boost (so same location on the fuel/spark table) but with different airflow.. this is why ECU's such as Pectel have features like "Multi-map".. it's a complex and slow mapping process! Ask any skyline owner!!
I'm not trying to bullshit you, I'm trying to help you with the facts. I didn't just make it up.
edit: manifold looks cool though.. might be worth getting it flow checked before you run it on the car.. to ensure even distribution..
Team HOTHOT!
it was run on a 2.1zvh that made over 300bhp so im confednt in it , my mapper alos said that u would say the same thing about people saying about need alpha , there is ways around this im just going my what my mapper has said and done for do u have msn so i can talk t u more about this with out killin this post , lukelavender @ hotmail.com ( wiht out spaces )
