caliper brackets
Old Aug 12, 2006 | 01:20 PM
Basky's Avatar
Basky
Default caliper brackets
2wd and 4x4 are they the same carrier brackets on the rear
Old Aug 12, 2006 | 01:24 PM
Alvyn's Avatar
Alvyn
no
Old Aug 12, 2006 | 01:46 PM
xr4x4rs's Avatar
xr4x4rs
what do you mean in brackets
if its where the caliper bolts to then yes they are
if its the sliding prt of the caliper that bolts to the hub then no
Old Aug 12, 2006 | 03:47 PM
Basky's Avatar
Basky
basicly i have 4x4 calipers ie the piston side
and have 2wd bracketry that bolts to the hub would this fit
Old Aug 12, 2006 | 04:40 PM
costina's Avatar
costina
Live long and prosper!!
No they won't u need complete 4x4 cals and discs or 2wd stuff
Old Aug 12, 2006 | 04:44 PM
Alvyn's Avatar
Alvyn
as stated above due to the 4x4 stuff being vented(so thicker than 2w/d)
Old Aug 12, 2006 | 05:34 PM
dojj's Avatar
dojj
Resident Wrestling Legend
no and no
the disc is vented on the 4wd cars so the bracket needs to be wider to accomodate this
the caliper will also need to be wider to fit over the disc properly
so, to reiterat, no and no
Old Aug 12, 2006 | 05:39 PM
_DAN_'s Avatar
_DAN_
Yoon
Originally Posted by dojj
no and no
Would aftermarket ventilated discs work tho?
Old Aug 13, 2006 | 07:49 AM
dojj's Avatar
dojj
how do you mean?
aftermarket vented discs will be the same dimensions (20mm width i think) so oyu've still got the problem of how to get a 20mm disc into a 0mm slot on the non vented caliper
if you fit a front disc set up to the rears (like some people do) then you would have to get a custom bracket made up to bolt to the rear end so that you could bolt the front calipers to it etc etc
Old Aug 13, 2006 | 09:21 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
no and no
definatly no!!
ive a cheap pair of 4x4 rears on ebay now with the correct caliper carriers for vented disc's.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
