Car electrical issues... **SORTED**
Old Aug 12, 2006 | 10:17 AM
Redeye Jedi's Avatar
Redeye Jedi
Default Car electrical issues... **SORTED**
Basically ive got a problem with my rear lights/brake lights! When the headlights are on it appears that my drivers side brake light is also on, however if i then brake the drivers side that was on prior to braking goes off and the passenger side brake light then comes on?!? Checked all the bulbs and connections to both rear clusters, 1 of the tail light bulbs had blown (well 1 of the 2 filaments inside it) but i replaced that and still have the same problem! Anyone got any tips for where to start tracking down this problem?? Obviously only a matter of time before i get pulled!!
Old Aug 12, 2006 | 10:24 AM
Ginge !'s Avatar
Ginge !
just finding my feet
mate its the connection thats needs polishing up mate, either that or the buld is in the wrogn way ( was it a tight fit to turn when ya installed it )
brish the connections and just look at the track to see if thees a birt join ect
Doug's Avatar
Doug
Neil check that you have put the correct type of bulb in mate I.e not a single contact in a double contact holder as this will send the lights to buggery .
Regards Doug .
Old Aug 12, 2006 | 10:27 AM
DazC's Avatar
DazC
Regards Doug .
Or a double fillament bulb in upside down. Or the fillament has blown and shorted across to the other fillament.
Redeye Jedi
Regards Doug .
No the replacement bulb is identical to the one i took out!! Bearing in mind that this problem was occuring before i changed the bulb!
Old Aug 12, 2006 | 10:28 AM
Redeye Jedi
So would u say its the connection from bulb to holder? I shall go and clean all of these connections and see how i get on! Would a poor connection from bulb to holder really cause this to happen though?? I mean all the lights work but at the wrong times!
Old Aug 12, 2006 | 10:30 AM
Redeye Jedi
Regards Doug .
The bulb is question is a double fillament bulb and when i checked it, 1 of the fillaments had blown and was touching the other, so i replaced it! Still no different though!!
Old Aug 12, 2006 | 10:32 AM
DazC's Avatar
DazC
Have you changed the other bulb on the other side as a precaution and have you 100% deffinately put the bulb in the right way?
Old Aug 12, 2006 | 10:34 AM
Redeye Jedi
Right i havent changed the bulb in the other side, ill go do that in a sec! Well as far as i can see theres only 1 way the bulb can go in
Old Aug 12, 2006 | 10:49 AM
Redeye Jedi
That was the answer!! 5 gold stars for u!! Another problem quickly rectified with the aid of PF!!
Old Aug 12, 2006 | 10:51 AM
Ginge !'s Avatar
Ginge !
hey i sugested that one,,,,, ust he explained it better
Old Aug 12, 2006 | 10:53 AM
DazC's Avatar
DazC
LOL!!
Glad it's sorted.
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
xr_craig
Aug 7, 2015 06:00 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
