induction kit or panel filter for cossie
whats best to go for
just got my first cossie n dont know shit bout tuning them!
seen is a K&N induction kit ok? do i just buy one thats designed for the saph cossie or need to find a group A one
ps whats the difference? are group A ones bigger?
already got a panel filter in it
but i see a lot of cossies in mags n at shows with cone filters on
im wanting to go to stage2/3 with my cossie
this is the K&N i was looking at
http://knfilters.com/search/product.aspx?Prod=57-0061-1
would i be best going grp A
or just sticking with my panel filter?
soz for my basic dumb questions, just used to tuning RSTs not cossies
while stationary they suck in hot air yes...
and whats wrong with a bit of noise? if you want a quiet car, buy a Toyota Prius and run it on leccy LOL
Caraholic
I think you would be surprised and would INSTANTLY retract your comment above .
my car is running a cone but still has the airbox feed in front of the filter
surely the intake temps dont matter that much when the air is just fed into a compressor at several hundred degrees anyways?
Caraholic
PS. I will have an EXACT answer to your boost gauge question shortly - I'm not ignoring you .
Have you EVER measured the under-bonnet heat build up whilst on track?
Caraholic
Just fit a cone filter and be done with it for three good reasons.
1. It's so much more simple and loses all that airbox nonsense.
2. It sounds far better, and wont make any noticeable difference on a road car whatsoever.
3. It'll piss Mike off
Originally Posted by Cawood
nice one, well that cheaper for me 2 then
do you make any mods to the air box? (like on RST's cutting the front out)
Yes, forgot to mention that both those pictured have the FRONT ONLY cut out for improved airflow .
First seen 3 years ago on a Red Es Cos:
Recently seen on another Es Cos at Ford Fair:
Ooooh, Doug you trendsetter!
Does it matter that Martin had that on his car years ago though?
If fact, I was nerveous about the likelyhood of the filter sucking rainwater and locking-up the engine, but when I showed my filter-in-bumper arrangement to Harvey (Gibb), he told me not to worry, because most of the RS500 touring cars had them fitted back in the late 80's.....some of those races were VERY wet
But I still DO worry and only use light throtle/low boost in heavy rain - just in case.......
Caraholic
with the front (bottom i presume) cut out mike, would you still get the "wastegate chatter" ( ) with no dv?
Mike,
Can you remind me please............
Who was it the modified his Es Cos air box 4 years ago, so that a T4 inlet hose could go straight in to the enlarged opening, without needing a machined reducer to restrict flow?
Caraholic
Originally Posted by Doug Stirling
Mike,
Your effort was just to push the hose in - very "Blue Peter" .
.......Your effort was just to push the hose in - very "Blue Peter"
Caraholic
Cant find those close-up pics of your engine bay with the "Aeroquip" fittings that you have do up/loosen with a screwdriver........Very "JML"
