intercooler options for saph 4x4
what I/C is best for the saph 4x4
want to upgrade, is the RS500 style best to go for?
will RS500 I/C's fit, or is it an RS500 style one i need
the pace RS500 jobby any good
Originally Posted by SapphyMike
ginge,
cant you fit an Esc Cos intercooler with charge cooler?
ginge,
can you pm me with a price for the intercooler with the work done, sent to me please mike?
will be in touch again soon as i want an act gauge and group a coil in the near future too
ginge,
Alternatively you could buy the chargecooler separation kit as well, which makes this a stand-a-lone set up, instead of using the engine coolant (much more efficient) and negates you having to buy the Ford parts mentioned above, or do the mod to the thermostat.
ginge,
sounds alot of work.
will keep it in mind. prob easier to junk the air con.
other things to do first though
like fit my gauge and pillar trims
ginge im useing a large turbo escort intercooler on mine with a seperate rad (heater matrix) and a pump without it on charge air temp is around 30 degree at 2 bar at somer temps reading with one of mr rainbirds gauges and at the ecu with the pump on about 24 degree if that helps
3doorcozmess
20-09-2015 06:15 PM
truffleshuffle
10-09-2015 09:35 PM
