escos dizzy cap
Old Aug 16, 2004 | 06:15 PM
Rob Virgo's Avatar
Rob Virgo
Default escos dizzy cap
again ,
for ian my buddy , he wants to know the difference between cat and non cat dizzy caps.
ford list both
rob
Old Aug 16, 2004 | 06:24 PM
richm's Avatar
richm
non-cat has horizontal HT lead outlets, later ones have vertical turrets.
AFAIK, the redtop and greentop engine versions of 4x4 Sapph had thes two different caps, but all Escos were Cat equipped, with the vertical turret cap..
Old Aug 16, 2004 | 06:29 PM
Billabong's Avatar
Billabong
Go for the vertical turret (Cat) one Rob
Old Aug 16, 2004 | 06:36 PM
richm's Avatar
richm
bear in mind you will need the correct HT leads to suit - the later ones have right-angled connections to plug into the vertical turrets.
Old Aug 16, 2004 | 06:40 PM
dave cos4x4's Avatar
dave cos4x4
that's what i was going to say.
Check his leads to see what cap he needs.
Bent leads.....straight cap.
Straight leads....bent cap.
Dave.
Old Aug 16, 2004 | 08:04 PM
Billabong's Avatar
Billabong
Could've sworn I had vertical turrets/straight lead ends ....but can't be RS'd to check until tomorrow.
The reason I said straight cap, was to avoid *possible* issues with the Motorsport lead (angled end type only) that *some* people had - forgetting about if he has std Beru leads - doh!
Old Aug 16, 2004 | 08:57 PM
richm's Avatar
richm
Bill,
there's no way straight leads in a vertical cap will fit under the inlet manifold..
Old Aug 16, 2004 | 09:02 PM
nomad's Avatar
nomad
the caps are interchangeable to a certain extent, you can fit a later type (vertical turret) onto the early type dizzy but not vice versa. as long as you change the leads that is. cheers nomad
Old Aug 16, 2004 | 09:08 PM
richm's Avatar
richm
indeed, exactly what i have, hence how i learned of the differences
Old Aug 16, 2004 | 09:09 PM
Billabong's Avatar
Billabong
I'm probably wrong then, my memory is crap lately, lol
I've got Motorsport leads if it makes any odds...... Oh well, it'll bug me now until I check in the morning
gcfcos
59
Oct 6, 2015 05:04 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
