4wd throttle position sensor resetting
Old 30-07-2006 | 11:40 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Default 4wd throttle position sensor resetting
How do you reset the throttle position sensor on a 4wd lump? My secs monitor is only reading 99% throttle when it is fully open, and when the engine was in the cossie, it read 100%.
Due to moveing the engine about etc etc, the tps may have been knocked a little.
Also, whats the best sump sealer for a 2wd sump? Mine is pissing oil out of the half moon at the front, and I need to change it on wednesday, otherwise no fordfair for me
Old 30-07-2006 | 12:09 PM
DazC's Avatar
DazC
Any sealant should be good enough as long as you make sure the surface is absolutely dry (oil) and clean.
I find the easiest way to set the throttle pot up is to remove the throttle body off the elbow. Otherwise you have to fuck around under the plenum.
Old 30-07-2006 | 01:30 PM
Andreas's Avatar
Andreas
If its underreading why not just tension the throttle cable?
Old 30-07-2006 | 01:42 PM
andre_k's Avatar
andre_k
dont know the answer to your question, but im looking foreward to seeing this at ford fair
Graceland's Avatar
Graceland
Team HOTHOT!
tensioning the throttle cable will not adjust the tps
Old 30-07-2006 | 01:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Thats If it gets there, now got a major problem with the brakes, or should I say, lack of
Old 30-07-2006 | 02:39 PM
Cosworth-aka's Avatar
Cosworth-aka
you can just about get at it from under plenum slacken off the screws and turn it (which way i cant remember) untill it hits its stop then tighten. its worth noting that the roller ball in the throttle linkage wears thus causing the butterfly to not open fully. very slight i know but could cause the secs monitor to read as it is
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
mk3ste
17-10-2021 11:09 AM
Brickhouse
14
03-10-2015 08:28 PM
Quick Reply: 4wd throttle position sensor resetting
