HELP PLEASE!!!!
I am fitting a oil, boost, water gauges to my 4x4 saff.
I have got the triple holed plate to go where my top air vent is the only problem is where from the engine bay do I feed the appropriate pipes and hoses to the gauges.
The only large gromet access that I can see is by the fuse box but that is on the other side of the engine bay that really I do not want to use.
Would I need to drill a hole in the bulk head if so any ideals.
Thanks.......
Thanks.......
There is a spare bung in the ECU loom grommet (just below the ABS valve block) that you can use for additional wires and pipes etc etc, All my SPA wiring was fed thru this, and what a pain in the arse it was, bloody big plugs on the end of the wires to squeeze through small holes
