pickup pipes - cosworth
does anyone have any definative answer to the position/height of the 4x4 setup vs the 2wd setup ????
so if you have a 2wd block/pump/pickup will this still be in the same height on a 4wd setup in the sump ????
anyone with either setup give me any measurements from the base of th epump to the base of the pick up ???
mine is all 2wd but with 4wd sump - oil pressure is fine but ive not driven it yet ??
cheers
cheers
AndrewStrang
01-09-2015 11:16 AM
borboyous
14-08-2015 06:51 PM
