General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
size disc can be fitted, 330 was max with my Rondells whats the next size up & will they fit under 17" Supperleggaras. I appear to have a more clearance is that so.
Thanks Rod
343mm discs will just fit under 17 Oz alloys with CP555s IIRC but 355s will not
Thanks do AP do that size.
Yes they do, you should go for 32mm width if your calipers will allow. You could get big gains just by changing pad material obviously this depends on what pads you use at the mo.
