new clutch problem.....please help
Old Jul 19, 2006 | 02:17 PM
Cowboi's Avatar
Cowboi
Default new clutch problem.....please help
i have just fitted a new clutch to my girlfriends 106.
it ended up being a bit of a nightmare.
but got worse at the end.
i bolted all the mounts uo, fitted the driveshafts back in etc.
then went to fit the clutch cable.
the arm that goes into the box is as floppy as anything.
it took me forever to get the box and engine to line up and really dont want to go through it all again.
what would cause the arm to be floppy?
Old Jul 19, 2006 | 02:19 PM
MAD EVO 4's Avatar
MAD EVO 4
Did you leave the thrust bearing out ??
Old Jul 19, 2006 | 02:21 PM
lawnsy's Avatar
lawnsy
As above ive done it in the past (trying to hurry to get the car back on the roads)
Old Jul 19, 2006 | 02:23 PM
MAD EVO 4's Avatar
MAD EVO 4
or it could of fallen off when trying it fit the box and now be laying in the bottom of the bell housing.
Old Jul 19, 2006 | 02:24 PM
Cowboi's Avatar
Cowboi
i put it on over the shaft in the box with the clips over the arm. let me just go and check it hasnt fallen out while i was moving the box to line it up with the engine.
is it box off again if the bearing is in the but not in the right place?
Old Jul 19, 2006 | 02:26 PM
MAD EVO 4's Avatar
MAD EVO 4
if it has fallen off, you will have to undo the bell housing bolts and see it you can prise the box away from the engine and see if you can get a hand up in there, if not the box will have to come out.
Oh you have got the clutch in and fitted all correctly with the friction plate the right way round ??
Old Jul 19, 2006 | 02:30 PM
lawnsy's Avatar
lawnsy
At least all the bolts are slack for you now it always comes apart quicker the second time round
MAD EVO 4's Avatar
MAD EVO 4
Old Jul 19, 2006 | 03:24 PM
Cowboi's Avatar
Cowboi
well i found it at the bottom of the pit.
box came off again but managed to get it away enough with the shafts in.
im about to check the arm so wish me luck
cheers for the help guys
Old Jul 19, 2006 | 03:26 PM
MAD EVO 4's Avatar
MAD EVO 4
good luck boss
Old Jul 19, 2006 | 03:35 PM
lawnsy's Avatar
lawnsy
Good luck
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
