who knows about cossie starter motor wiring
Old 11-07-2006 | 08:35 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default who knows about cossie starter motor wiring
as in how many wires og on it and where they lead too
what ive got so far is red ontop bat and then a plug type that leads into the loom
also is th oil presure switch attached to that plug as ive got a wire spare
is there any other sires im missig or does the small wire do th rest
Old 11-07-2006 | 08:37 PM
SPADGE's Avatar
SPADGE
To the starter is just the main live feed from the battery and a small spade to it also.
The oil pressure wire is part of the same bit of loom so will be there also
Old 11-07-2006 | 08:38 PM
Graceland's Avatar
Graceland
Team HOTHOT!
2 wires to the starter
13mm nut on the starter - permanat main feed, 60 amp cable MINIMUM.
10mm nut - solenoid trigger feed from the back of the ignition switch - 15amp cable
Old 11-07-2006 | 09:12 PM
Ginge !'s Avatar
Ginge !
cool as thats what i got
cheers for your help gues and FINALLY i foudn the oil presure light switch wire,,,,,,,, never had one on the car since i bought it hence how i ran it with no oil
Old 11-07-2006 | 09:14 PM
Ginge !'s Avatar
Ginge !
oh is there just 2 wires on the neg of the bat too, 1 on the engine and infront of the bat on the shell and another brown wire that goes with the loom above the engine forward
Tank Mike
Ford Focus Diesel
23-02-2022 07:09 PM
jay030787
18-09-2015 05:38 PM
marky_g
12-09-2015 05:26 PM
cossie09
10-09-2015 07:56 PM
dojj
08-09-2015 09:31 AM
