low fuel splutter on accellerating???
if i let my 2wd saff fuel level get near the 1/4 level on the gauge when i accellerate hard it pulls in 1st then dies for a second when changing into any other gear but since keeping loads more fuel in has been fine.. has anyone else had this problem..?? cheers
Change your fuel tank - sounds like the accumulator is not filling properly (tank dented or internal blockage) causing air to be drawn into pump and onto the fuel rail. Probably OK in first, because the car has been sitting at idle, so accumulator has time to fill (but more slowly than it should). Had exactly the same problem on my saff with the original Ford tank when 1/4 full or less.
how often do they need changing.. ? its only started doing this since fitting braided fuel lines and turning the fuel filter round to join to the pump with screw fittings..
i have been thinking maybe the tank.. although its brand new last year if i take the feed hose off the tank i would have expected the whole tank to empty but only a trickle comes out then stops? or should it do this..?
it is one of these pattern tanks not a ford one.. if i keep the car full of fuel it runs fine..
it has no dents in the tank but when i tried to get the fuel out of it when off the car i did shake the fook out of it.. still none came out of where i wanted it to tho..
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
