Oil labelling explained
Old Jun 27, 2006 | 02:41 PM
oilman's Avatar
oilman
Default Oil labelling explained
What’s written on your oil bottle and what does it mean.
This post may seem like going back to basics but I am constantly surprised by the amount of people who do not know or understand what is written on a bottle of oil and therefore no idea of what they are buying/using.
To be blunt about the subject, if a bottle of oil does not contain the following basic information then DO NOT buy it look for something that does!
1) The purpose for which it is intended (i.e. Motor oil, Gear oil etc)
2) The viscosity (i.e. 10w-40, 5w-30 etc for Motor oils and 80w-90, 75w-90 etc for Gear oils)
3) The specifications that it meets (should contain both API and ACEA ratings)
4) The OEM Approvals that it carries and the codes (i.e. MB229.3, VW503.00, BMW LL01 etc)
Ignore the marketing blurb on the label it is in many cases meaningless and I will explain later what statements you should treat this with some scepticism
So, what does the above information mean and why is it important?
THE BASICS
All oils are intended for an application and in general are not interchangeable. You would not for example put an Automatic Transmission Oil or a Gear Oil in your engine! It is important to know what the oils intended purpose is.
VISCOSITY
Most oils on the shelves today are “Multigrades”, which simply means that the oil falls into 2 viscosity grades (i.e. 10w-40 etc)
Multigrades were first developed some 50 years ago to avoid the old routine of using a thinner oil in winter and a thicker oil in summer.
In a 10w-40 for example the 10w bit (W = winter, not weight or watt or anything else for that matter) simply means that the oil must have a certain maximum viscosity/flow at low temperature. The lower the “W” number the better the oils cold temperature/cold start performance.
The 40 in a 10w-40 simply means that the oil must fall within certain viscosity limits at 100 degC. This is a fixed limit and all oils that end in 40 must achieve these limits. Once again the lower the number the thinner the oil, a 30 oil is thinner than a 40 oil at 100 degC etc. Your handbook will specify whether a 30, 40 or 50 etc is required.
SPECIFICATIONS
Specifications are important as these indicate the performance of the oil and whether they have met or passed the latest tests or whether the formulation is effectively obsolete or out of date.
There are two specifications that you should look for on any oil bottle and these are API (American Petroleum Institute) and ACEA (Association des Constructeurs Europeens d’Automobiles) all good oils should contain both of these and an understanding of what they mean is important.
API
This is the more basic as it is split (for passenger cars) into two catagories. S = Petrol and C = Diesel, most oils carry both petrol (S) and diesel (C) specifications.
The following table shows how up to date the specifications the oil are:
PETROL
SG - Introduced 1989 has much more active dispersant to combat black sludge.
SH - Introduced 1993 has same engine tests as SG, but includes phosphorus limit 0.12%, together with control of foam, volatility and shear stability.
SJ - Introduced 1996 has the same engine tests as SG/SH, but phosphorus limit 0.10% together with variation on volatility limits
SL - Introduced 2001, all new engine tests reflective of modern engine designs meeting current emissions standards
SM - Introduced November 2004, improved oxidation resistance, deposit protection and wear protection, also better low temperature performance over the life of the oil compared to previous categories.
Note:
All specifications prior to SL are now obsolete and although suitable for some older vehicles are more than 10 years old and do not provide the same level of performance or protection as the more up to date SL and SM specifications.
DIESEL
CD - Introduced 1955, international standard for turbo diesel engine oils for many years, uses single cylinder test engine only
CE - Introduced 1984, improved control of oil consumption, oil thickening, piston deposits and wear, uses additional multi cylinder test engines
CF4 - Introduced 1990, further improvements in control of oil consumption and piston deposits, uses low emission test engine
CF - Introduced 1994, modernised version of CD, reverts to single cylinder low emission test engine. Intended for certain indirect injection engines
CF2 - Introduced 1994, defines effective control of cylinder deposits and ring face scuffing, intended for 2 stroke diesel engines
CG4 - Introduced 1994, development of CF4 giving improved control of piston deposits, wear, oxidation stability and soot entrainment. Uses low sulphur diesel fuel in engine tests
CH4 - Introduced 1998, development of CG4, giving further improvements in control of soot related wear and piston deposits, uses more comprehensive engine test program to include low and high sulphur fuels
CI4 Introduced 2002, developed to meet 2004 emission standards, may be used where EGR ( exhaust gas recirculation ) systems are fitted and with fuel containing up to 0.5 % sulphur. May be used where API CD, CE, CF4, CG4 and CH4 oils are specified.
Note:
All specifications prior to CH4 are now obsolete and although suitable for some older vehicles are more than 10 years old and do not provide the same level of performance or protection as the more up to date CH4 & CI4 specifications.
If you want a better more up to date oil specification then look for SL, SM, CH4, CI4
ACEA
This is the European equivalent of API (US) and is more specific in what the performance of the oil actually is. A = Petrol, B = Diesel and C = Catalyst compatible or low SAPS (Sulphated Ash, Phosphorus and Sulphur).
Unlike API the ACEA specs are split into performance/application catagories as follows:
A1 Fuel economy petrol
A2 Standard performance level (now obsolete)
A3 High performance and/or extended drain
A4 Reserved for future use in certain direct injection engines
A5 Combines A1 fuel economy with A3 performance
B1 Fuel economy diesel
B2 Standard performance level (now obsolete)
B3 High performance and/or extended drain
B4 For direct injection car diesel engines
B5 Combines B1 fuel economy with B3/B4 performance
C1-04 Petrol and Light duty Diesel engines, based on A5/B5-04 low SAPS, two way catalyst compatible.
C2-04 Petrol and light duty Diesel engines, based on A5/B5-04 mid SAPS, two way catalyst compatible.
C3-04 Petrol and light duty Diesel engines, based on A5/B5-04 mid SAPS, two way catalyst compatible, Higher performance levels due to higher HTHS.
Note: SAPS = Sulphated Ash, Phosphorous and Sulphur.
Put simply, A3/B3, A5/B5 and C3 oils are the better quality, stay in grade performance oils.
APPROVALS
Many oils mention various OEM’s on the bottle, the most common in the UK being VW, MB or BMW but do not be misled into thinking that you are buying a top oil because of this.
Oil Companies send their oils to OEM’s for approval however some older specs are easily achieved and can be done so with the cheapest of mineral oils. Newer specifications are always more up to date and better quality/performance than the older ones.
Some of the older OEM specifications are listed here and depending on the performance level of your car are best ignored if you are looking for a quality high performance oil:
VW – 500.00, 501.00 and 505.00
Later specs like 503, 504, 506 and 507 are better performing more up to date oils
MB – 229.1
Later specs like 229.3 and 229.5 are better performing more up to date oils.
BMW – LL98
Later specs like LL01 and LL04 are better performing more up to date oils.
FINALLY
Above is the most accurate guidance I can give without going into too much depth however there is one final piece of advice regarding the labelling.
Certain statements are made that are meaningless and just marketing blurb, here are a few to avoid!
Recommended for use where……………
May be used where the following specifications apply……………
Approved by………………………..(but with no qualification)
Recommended/Approved by (some famous person, these endorsements are paid for)
Racing/Track formula (but with no supporting evidence)
Also be wary of statements like “synthetic blend” if you are looking for a fully synthetic oil as this will merely be a semi-synthetic.
Like everything in life, you get what you pay for and the cheaper the oil the cheaper the ingredients and lower the performance levels.
If you want further advice then please feel free to ask here or contact us through our website at www.opieoils.co.uk.
Simon
Old Jun 27, 2006 | 04:21 PM
Andy_R's Avatar
Andy_R
Good info, thanks Simon
Old Jul 12, 2006 | 12:49 PM
oilman's Avatar
oilman
Thanks, more people should read it! 64 views
Simon
Old Jul 12, 2006 | 12:53 PM
bud-weis's Avatar
bud-weis
Football Cwazy
good info...so many people who think the W is for Watt
Old Jul 12, 2006 | 01:00 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Simon, what would you recommend for a standard K plate E36 BMW 325i?
Old Jul 12, 2006 | 01:59 PM
oilman's Avatar
oilman
5w-40 full synthetic, have a look at the Fuchs Titan Supersyn SL 5w-40.
Simon.
Old Jul 12, 2006 | 02:07 PM
Markb_s1's Avatar
Markb_s1
nice one Simon
nice to know a bit more abotu what i'm putting in my enignes!
Old Jul 12, 2006 | 03:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Usefull info, seeing as i know F'all about oil !
Old Jul 12, 2006 | 05:18 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
what is the best for a cossie YB then? Std and modified, as there seems to be a huge amount of disagreement about whats best to use
Old Jul 12, 2006 | 05:29 PM
MAD EVO 4's Avatar
MAD EVO 4
Very good post
Old Jul 12, 2006 | 08:17 PM
oilman's Avatar
oilman
Well it depends.
Modded/hard used 10w-50/15w-50.
Standard/light use 5w-40.
Simon.
Old Jul 12, 2006 | 11:33 PM
paconassa's Avatar
paconassa
best oil then:
10w50
api SM
acea a5
and loads of oem recomend's!!!!!
Old Jul 13, 2006 | 07:11 AM
gingeRS's Avatar
gingeRS
interesting read
Have just ordered 2 bottles of your finest golden syrup for my saff, should be winging its way to me, as we speak.
silkolene 10w-50 - stage 3 saff
bargain price too, got it cheaper from you, than i could have done anywhere else (collection) and you delivered it to my door for that price.
Old Oct 13, 2006 | 02:56 PM
oilman's Avatar
oilman
If you missed this first time around, it's worth reading
Guy
Old Oct 13, 2006 | 04:11 PM
se mk3 cabbie's Avatar
se mk3 cabbie
whats recommended for rs turbo (cvh) please mate and very interesting read mate, didnt have a clue what all that meant before, may aswell of been written in german
Old Oct 13, 2006 | 04:17 PM
oilman's Avatar
oilman
If the engine is in good shape then a good 5w-40 synthetic is ideal.
Guy.
Old Oct 13, 2006 | 04:46 PM
se mk3 cabbie
Guy.
cheers mate
Old Oct 13, 2006 | 05:57 PM
phil4x4saph's Avatar
phil4x4saph
Excellent work chap!
I will print that off and stand over the numpties at work till they know it word for word!!
Old Oct 13, 2006 | 06:08 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Well it depends.
Simon.
so is mobil 1 15/50 good for a highly moded cos then....i use this
Old Oct 13, 2006 | 07:03 PM
PaulCossie's Avatar
PaulCossie
Well worth the read, Thanks for the info
Old Oct 13, 2006 | 08:09 PM
oilman's Avatar
oilman
Well it depends.
Simon.
It's good stuff yes, there are better ones out there but not many available off the shelf.
Simon
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
