Which fiesta?
prob is i dont know anywhere near me that would be able to do specialist work like engine swaps otherwise id put a big engine in me KA!
big engine little car big fun!
Originally Posted by andyh4324
what if i tuned the engine in the zetec s?
likely power? what would i have to put in to get it?![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
The right cams for the job ( pm for details ), raised rev limit and a remap. With any luck will see 140-150 bhp. I'd recommend a phase two Z-s as the cam follower arrangement is more stable at higher rpm. However the cams are an arse to fit as the valve clearances need to be set with ground 'top hat' shims, so theres a bit of work to do there.
All that with T'bs you'd be seeing 170-180 plus, but you'd need a few bottom end revisions and new management
sound good for a little car! how much would that little lot cost du think?
Cams £4-500
Zaust £270
4-2-1 £270
Sportcat £200
Cam fitting, valve clearances set properly with ground top hat shims - £3-400
Custom remap - not an off the shelf chip - £4-500?
So at least the thick end of two grand if not more.....you could go ARP rod bolts for safety but you wouldnt be revving lots more over standard unless you went the TB and wilder cams route
Originally Posted by Stu @ M Developments
RS1800 far superior car to the FRST. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Can you check your PMs as well please, ta
Mrs had an RS1800 for a while. Great car, loved it
Steve Escos
01-10-2015 06:57 AM
