High Impedence Injectors...where from?
Hi peeps, just wondering if anyone can help me...im after a set of high impedence injectors that are over 650cc....ideally 750cc - 800cc if not bigger...can anyone help or recommend where to get a set?
im going to ring Norris Designs tomorrow and see what they have to offer...but looking at the price differences between Simon and Mike R, there must be a HUGE difference between the two that they sell!...
are Mike R's injectors high or low impedence?
also does anyone know what the highest flow rate high impedence injectors there are available at the moment?
thanks for any input
bassboy
bassboy
Ł300 1000cc and 750cc in stock
low inmpedence same size as a cozzy injector
bewere !!!!!! most or some cheap injectors are smaller in lenght that cozzy ones and cause air leaks or fuel leaks
if changin injectors may b u need billet rail aswell
brom got any in high impedence? have to be high as the vehicle will be running Pectel T2...
Gareth its for an engine im building at the moment...they NEED to be HUGE
bassboy
bassboy
Gareth ill post up details here in due time mate...we just need to finalise a few things regarding this engine then we can get it on the dyno
oh and silly power is the way to go
simon...might have to do that mate...whats involved in this?
bassboy
bassboy
A metal box with 4 high current transistors and injector current feedback
control circuit.
2 power wires input.
4 injector input wires.
4 injector output wires.
Have built these before for upgrading EEC4 ecu's
control circuit.
No, it is fitted EXTERNALLY to the ecu so there should be no waranty issues.
The inteface has load resistors to simulate the high impedance injectors.
(16 ohms)
The inteface can then drive ANY type of injector you desire.
There is no special ecu set up required and can be mapped normally.
I will need about 10 days notice if you need this.
(16 ohms)
bassboy
Check with your mapper if he is willing to map with Simons kit first, Also ask the Ecu suppler about the injectors,
I would not supply a unit and then not help with the injectors or supply what you want.
Mark
Mark
cheers Simon, i will keep this in mind and will check with the mapper if he is willing to use the product
mark will check with him first and see what he says...can you supply or know of where i can get these injectors from?
bassboy
bassboy
bassboy
bassboy
Mark
control circuit.
control circuit.
you can get bigger than 750 but think they are special order.
bought mine from the us www.rceng.com
can get them cheaper of any store on fleebay
http://cgi.ebay.com/ebaymotors/RC-FU...QQcmdZViewItem
Im using 6 x 650cc low impedance on a V6 Turbo build..
have u tried to order custom size?
Rossco...i wish it were that easy
bassboy
1000cc or 8 x 450cc ish injectors
Most ECUs worth their salt are capable of running 8.
That sort of output on any 4 pot is pretty serious stuff. What / who's engine is it?
the manifold has been done to accept 4 LOL...ill see if the design can be changed to accept 8 as i think it will be ALOT easier LOL
the engine is for a friend of mine
i will display the results once the engine has been on the dyno
bassboy
bassboy
think they ordered some 970 cc of msd(they have stopped making them
harvey (gibbs) are making some cossie/T2 conversions aswell as mr godfrey
maybe ask them about injectors
i know sard are making 850cc top feed injectors but dont know how they fit lengthwise on the cossie engine.
need to make new connectors on the loom tho
have tried to contact rc myself.want to get some 1200cc for my car.
thinking of running it on E85 (methanol/95ron unleaded mix)
using this fuel you need atleast 30% bigger injectors than on normal petrol
so far it runs on 750cc and 98 ron.should produce the required 204 bhp
cheers
cheers
mark how much for the 750cc's? can u get any bigger than that?
garage19..cheers for the info
i will let u know if i need it
bassboy
bassboy
My laptop for all the costs on has just died
Mark
capri-rs ok cheers mate, will be getting on the phone to a few peeps tomo and seeing what they recommend and can supply
Mark...ill give you a ring tomo and see what i can get through you
Faye...waiting for him to give me a reply to my email LOL
bassboy
bassboy
07-10-2015 12:56 PM
