WHEEL SIZES????
Old Jun 10, 2006 | 02:10 PM
mercury grey minter's Avatar
mercury grey minter
Default WHEEL SIZES????
Need to know what offset wheel i may need as the ones iv,e got,the back of the spoke touches the face lof the caliper,by the sticker.Don,t quite understand tne numbers.Mine are 7x17 ET40.
Old Jun 10, 2006 | 02:19 PM
Rab's Avatar
Rab
Fucking superstar........
ET40 is the wrong offset for your S2. It needs to be ET35. Get a 5mm spacer and you're sorted
Old Jun 10, 2006 | 07:39 PM
mercury grey minter
[quote="Rab"]ET40 is the wrong offset for your S2. It needs to be ET35. Get a 5mm spacer and you're sorted [
/quote]
Got a 5mm spacer today,still touches Think it might be the rim design.How do other people get big brakes on series 2???
Old Jun 10, 2006 | 07:42 PM
Rab's Avatar
Rab
What size are the brakes? Cos I've seen 330mm and 4 pots on a s2 no bother
Old Jun 10, 2006 | 07:44 PM
mercury grey minter
They are 320mm focus rs calipers and discs.Are alloy bells an option with these discs?
Old Jun 10, 2006 | 07:47 PM
Rab's Avatar
Rab
That explains it.... I think you'd need 18's to clear them....
Old Jun 10, 2006 | 07:54 PM
tonyturbo's Avatar
tonyturbo
sure christian has 16" rims with these brakes, so thats not really an issue tbh. it probably is the design of the rim as thats why most folk use comp mo's because they have most caliper clearance...... i could be wrong of course...
mercury grey minter
Have seen 2 people with 17,s.Pretty sure it can be done.
Old Jun 10, 2006 | 07:59 PM
xr4x4rs's Avatar
xr4x4rs
by the looks of it its the wheel design and offset
you should be using et35 , the main problem is the design as the spokes are straight, if they were curved then you wouldnt have any issues i rekon
try and get hold of a diferent 17 rim and try it to see if they clear then
Old Jun 10, 2006 | 08:08 PM
mercury grey minter
Yep think that,s the problem(rim design) Will probably go for mo,s.Thanks anyway guys
Old Jun 10, 2006 | 09:23 PM
mercury grey minter
http://cgi.ebay.co.uk/FORD-alloy-whe...QQcmdZViewItem
Could i use these??Has anyone else used them before?
Old Jun 11, 2006 | 09:09 AM
mercury grey minter
ANYONE????????????????
Old Jun 11, 2006 | 10:45 AM
jon@work's Avatar
jon@work
40 - 17 = ET23. Not much chance of not catching your arches. Change your wheels, or get bells and brackets with more offset.
Old Jun 11, 2006 | 01:59 PM
mercury grey minter
New wheels me thinks.
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Mk5brown
Sep 9, 2015 12:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
